850 - Sensor on the sump?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=38790
Author:  meehal [ Sun Dec 16, 2007 8:59 pm ]
Post subject:  850 - Sensor on the sump?
I was under the mini today and noticed a sensor on the front right coming from the sump, its not connected to anything but it has the two connectors for something?
Any ideas? Electrical temp sensor? guessing....
meehal.
Author:  64cooper [ Sun Dec 16, 2007 9:01 pm ]
reversing lights
Author:  Wombat [ Sun Dec 16, 2007 9:06 pm ]
What he said^^^ - power supply in - lead out to reversing light When reverse is selected the power is supplied to the globe which has the other side earthed.
+ _____________/ ________--globe--______ _ earth
Author:  meehal [ Sun Dec 16, 2007 9:14 pm ]
ha thats interesting. i the lights with reverse just brake and indicate.
thanks for that very helpful.
Author:  Wombat [ Mon Dec 17, 2007 7:53 am ]
You can wire up your indicators to act reversing lights. You need 3 diodes (4 if you want to use both indicators - separate supply to each side - don't loop a wire from one globe to the other or both sides will flash) (1N400*) will do - anything over 1N4001 is overkill but will do the job)
wire one into each supply lead to the globe + ---->|---- globe---earth
Author:  Timbo [ Mon Dec 17, 2007 8:20 am ]
Later cars used dual filament globes in the indicators. On filament for flash the other for reveres. It gives you a slightly pale amber reverse light but better than nothing.
