It is currently Fri Aug 01, 2025 9:51 pm
PostPosted: Mon Dec 17, 2007 9:27 pm
so can it?? can you buy a replacment panel for the inner passenger side gaurd?
but instead of being a grill i want to replace it with a blank panel, can you buy them ?
was there an model of the mini that never had a grill there? :?:
mines a bit distorted and bentish any way and id like a smoother bay
Mearcat wrote:
PostPosted: Mon Dec 17, 2007 9:29 pm
Get some tin and cut it to shape, or cut the radiator grill out and weld a panel in.
PostPosted: Mon Dec 17, 2007 9:31 pm
unless you're running a dedicated front mount radiator you'll need the grill there :wink: it gives the air through your radiator somewhere to go
PostPosted: Mon Dec 17, 2007 9:37 pm
the plan is 4efte..... very slowly as my money tree grows
the housing for the head light is very much bent too
as well as this but thats all the pic that i had
Mearcat wrote:
PostPosted: Mon Dec 17, 2007 9:56 pm
Looks pretty close to factory to me.
PostPosted: Mon Dec 17, 2007 10:54 pm
yeh but theres a tiny little scratch !! :shock: :P
na you sort of have to see it in the real
Mearcat wrote:
PostPosted: Mon Dec 17, 2007 11:33 pm
i wouldn't be worrying about that now, wait until your well into it before you start worring about stuff like that..
cut it away get the motor in and weld a new panel around it to the shape required. Then remove motor and paint everything and put the motor back in ;)
PostPosted: Mon Dec 17, 2007 11:42 pm
sweet!
you sound like you have done this sort of thing before :lol: :lol:
see i was planing to put my radiator in the same position as yours any ways
Mearcat wrote:
