It is currently Sat Jul 19, 2025 8:54 am
 Post subject: engine internals
PostPosted: Sun Jan 09, 2005 2:29 pm
Hi,
Does anybody know if an 1100S short journal crank and internals will bolt straight into a Mk1 Cooper S block.
Thanks
PostPosted: Sun Jan 09, 2005 6:13 pm
Yes will fit but will have to play around with thrust washers, and end float
Miniworx Centre 0883741299
Online BMW Mini Shop
PostPosted: Sun Jan 09, 2005 6:20 pm
You can get std, +.003" and +.030" thrusts. But the +.030" are NLA according to many sources, including Karcraft. Vandervell stopped making them.
If you got 'em, hoard 'em! :P :wink:
PostPosted: Sun Jan 09, 2005 8:38 pm
Hi,
Thanks for your knowledge.
PostPosted: Mon Jan 24, 2005 7:58 pm
Do the 1100S crank and internals also fit inside the Mark 2 Cooper S block?
Thanks Again
PostPosted: Mon Jan 24, 2005 8:06 pm
Yes. Mk1 & Mk2 S main journal widths are the same, so the above applies.
The opposite applies too. I run a Mk2 S crank & rods in an 1100S block. Again, just need to play with the thrust washer thicknesses to get the end float right.. :wink:
PostPosted: Mon Jan 24, 2005 8:13 pm
Thanks Dr again
PostPosted: Tue Jan 25, 2005 9:00 am
Thats good to know I wil do that with my Next Motor. :lol:
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
 Post subject: ???????
PostPosted: Wed Jan 26, 2005 4:38 pm
Hey Guys
I was just wondering what i should do to my mini clubman that will make it preform better and what price i would be looking at
thanks
Blackrz
(998cc Clubman)
- = :Zone 3 Goober: = -
http://photobucket.com/albums/y142/blackrz/?sc=1
"I Live My Life A Quater Mile At A Time"
PostPosted: Fri Feb 04, 2005 9:05 am
Hi,
Another crank question.
I was reading an old mini magazine and it said,
If you use a LS1275 big journal crank (1.75 big ends), offset machine the big ends down to 1.625 diameter use this in a Cooper S block you will get an 1/8 of a stroke. Does this simply mean you just grind your LS crank down to 1.625 on the big ends and put it in a Cooper S block and you get an 1/8 stroke.
Thanks
PostPosted: Fri Feb 04, 2005 1:36 pm
Gezo wrote:
Hi,
Thanks
You need to offset grind the big ends to 1.625". This means they are set up in the grinder to take 99% of this metal off the inside of the pin, and bugger all off the outside. This moves the reground pin's stroke radius outwards.
Then you use S rods, but they are too wide and must be narrowed to fit.
And the pistons will now stick out of the block. So you need to get `stroker' pistons with a shorter pin to crown height. Sometimes you can machine the piston top of stock pistons, if thick enough. Not always.
Whether a 1275S block or later 1275 block doesn't matter. They are pretty much the same deck height.
PostPosted: Fri Feb 04, 2005 10:23 pm
Thanks again Dr.
Is this worth doing, and what sort of power gain is there.
Thanks
PostPosted: Sat Feb 05, 2005 6:04 am
Gezo wrote:
Thanks again Dr.
Thanks
You do gain torque, but I think it reduces revability. Crank is a bit more `whippy' than stock due to the extra stroke..
I'm tossing up now whether to bore my auto block to 1360, or stroke it to 1405. :?
I'll probably stay at 1360, I've got Hypatec pistons already. 8)
PostPosted: Sat Feb 05, 2005 11:11 am
Gezo wrote:
Thanks again Dr.
Thanks
Careful Doc - you're giving away a few Wakefield Park secrets there. Now the guys will know what you have up your sleeve :D :wink:
