It is currently Wed Aug 06, 2025 11:08 pm
PostPosted: Wed Dec 19, 2007 3:50 pm
What was the timing of the introduction of alternators on Australian built Minis and what model alternators were used (I'm assumimg they were all Lucas)? I seem to remember the MK II S I bought new in 1969 had an alternator with a separate control box mounted beside the power brake booster (16ACR?) but I've seen pictures of later S's showing an alternator with an integrated control box. Were these integrated types fitted by the factory or are they later replacement items?
In Pottsy's article on page 36 of the latest TME mag he says alternators came in from about 1971 onwards but I feel it was a bit earlier than that, although my copy of PUB1056M Mini Parts Catalogue that covers the MK II only mentions a generator.
PostPosted: Wed Dec 19, 2007 4:31 pm
Mk 1.5's onwards had the externally regulated alternators.
Life certainly got better therafter...
PostPosted: Wed Dec 19, 2007 4:36 pm
No such thing as a Mk1.5. 8)
The changeover was in mid 1969 right through the range.
PostPosted: Wed Dec 19, 2007 4:38 pm
And two types 4TR and then the 8TR, both NLA I believe.
PostPosted: Wed Dec 19, 2007 4:41 pm
As I said in another thread today, they are still about...
http://www.autoelectricsupplies.co.uk/product/706
I'm looking at one, in a green Lucas box... :lol:
PostPosted: Wed Dec 19, 2007 4:47 pm
There's no emoticon for blowing a raspberry at ya!
there was one on ebay that sold a week or more ago for $19.90 (4TR)
I was going to buy it but didnt need it so i didnt bother
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... :IT&ih=017
PostPosted: Wed Dec 19, 2007 5:02 pm
So what's the best guess on when the changeover from external to internal regulator type took place? What were the alternator models? The early one would have been ??AC and the later ??ACR according to my research so far.
PostPosted: Wed Dec 19, 2007 5:59 pm
I believe the changeover happened around start of Clubby production, in late 1971- I've never seen a Clubby with the 15AC alternator and separate 4TR or 8TR regulator as used on Mk2 S, Mini-K and Minimatic.
Clubbys here were mostly 15ACR and 16ACR, then 17ACR (late ones I think) all with internal regulator. More reliable and cheaper to fix... :wink:
PostPosted: Wed Dec 19, 2007 6:15 pm
I'm always happy to be corrected if I have something wrong. I was sort of guessing on the date of intro anyway. (Not being a Trainspotter I don't have all these kinds of numbers on hand, and being over 50 probably wouldn't remember them anyway!)
That being said, unless you're a real purist, then you can explore the possibilities of using a unit from a small Jap car, or maybe a Bosch unit. All it takes is a bit of adaptation sometimes.
And incidentally, the alternators used on most early Commodores were apparently Lucas and of a higher capacity than the one's that came on Minis. With a bit of care you can use the Mini housings so that it'll mount easily, and the Commodore insides so you have more output current available.
Is there no end to the ingenuity of Mini people?
Cheers, Pottsy
PS, I'd go for one with an internal regulator every time. It's just so much easier to deal with!
Smile Up at The Trucks!
PostPosted: Wed Dec 19, 2007 6:22 pm
During the late 60s and early 70s Holden used a lot of both Lucas and Bosch stuff. You could have a car that was all Lucas or all Bosch. I had a Torana that had Lucas alternator, Lucas starter, Lucas distributor and Lucas Coil. Most were all Bosch. I think it was a case of supply. Neither manufacturer had the capacity to supply all of Holdens needs so they shared.
PostPosted: Wed Dec 19, 2007 6:27 pm
Thanks Pottsy, I was hoping you were a member and would read this thread.
In my case I start out being a 'purist' in my restoration and only change things if there's a reason (e.g. original component unreliable or no longer available or lack of parts). Hence wanting to know what alternators were fitted to what cars coming out of the factory. We seem to be narrowing it down. Thanks for your contribution.
PostPosted: Wed Dec 19, 2007 10:08 pm
my clubman gt has a 15AC alternator and no external regulator, but other earlier Gt's do
PostPosted: Thu Dec 20, 2007 7:44 am
I've got a Clubman alternator to work on today...you should try finding an auto spark who will sell you the regulator itself in this area (it needs a 14TR reg.)...sheesh..
They all want to sell you a complete alternator at a marked up price...
PostPosted: Thu Dec 20, 2007 9:04 am
I got an 8TR from Mini King
