It is currently Wed Aug 06, 2025 5:10 am
 Post subject: CV JOINT NUT
PostPosted: Thu Dec 20, 2007 11:00 am
I purchased a "BTA249 <B> CV JOINT NUT - MINI COOPER S"
I have a 1-5/16 3/4Sq Drive socket, but it is too small for the nut.
What size socket should I purchase?
1978 NUGGET GOLD 1275 LS - 1380cc
1969 Morris Mini 1100cc
PostPosted: Thu Dec 20, 2007 11:18 am
1 5/16 is the correct size socket for a disc brake CV nut.
It should fit the CV if you have 7.5" discs, or the 8.4" discs.
The only other size is a smaller nut fitted to drum brake and Cooper 997 disc brakes which you say is the reverse of the problem here.
What kind of brakes do you have?
 Post subject: Type of brakes
PostPosted: Thu Dec 20, 2007 11:25 am
I have 8.4 disc for LS1275
Just got the socket.
It has "CR-MO 1-5/16" on the side of it.
PostPosted: Thu Dec 20, 2007 11:43 am
Yeah then it's the right socket, but something might be fouling the nut, or there's a problem with the nut or socket.
Using a ruler, measure across the nut from flat to flat. You should get a measurement of 33.34 (to be accurate) but get the best indication you can. If it's larger than this by a margin, then the nut has probably been machined from metric stock or something similar.
Other than that, make sure the edges of the nut aren't deformed to stop the socket sliding on (You might need to persuade it a little with a hammer to slide on) and see if you can inspect and measure the socket as well (it's a little difficult to do so without verniers).
One of these will be the culprit.
PostPosted: Thu Dec 20, 2007 11:45 am
I bought one recently and was sent metric as well........annoying...........
PostPosted: Thu Dec 20, 2007 12:04 pm
Thanks Mick and Smac for the help
Sounds like the nut is metic. I know how it feesl Smac, it is annoying.
Now i know to take the socket with me to test the nut on the next purchase.
Thanks, again
PostPosted: Thu Dec 20, 2007 1:48 pm
I bet a beer that it's metric... ones I bought recently in a CV joint as a kit were all metric...
PostPosted: Thu Dec 20, 2007 7:27 pm
The new nuts being supplied seem to be mostly metric. I could get my son to check the ones on the moke but I think they are a 31mm socket.
1964 998 Cooper , 1968 Morris 1100
PostPosted: Thu Dec 20, 2007 8:20 pm
I have a 34mm socket :?
PostPosted: Thu Dec 20, 2007 8:49 pm
Show off.
PostPosted: Thu Dec 20, 2007 9:17 pm
They are 34mm metric hexagonal bar stock now, because they are made elsewhere than UK.
It is annoying- when I got the first pair, I put them on the mill and made them 1-5/16" to fit my socket..
Since then I've bought a 34mm socket. :wink:
PostPosted: Thu Dec 20, 2007 9:19 pm
I've got one of each :roll:
PostPosted: Thu Dec 20, 2007 9:20 pm
Yeap 34mm Socket - fits both 8)
PostPosted: Thu Dec 20, 2007 9:21 pm
Let me know if you want to use it Gimpy..I'm in Baulkham Hills
