I considered the AMR300 route but I did all the calculations and you really can't run much boost without spinning the pool lil thing waay faster then it's sposed to even on an 1098cc
I reckon an AMR 500 would be perfect if you want low to medium boost and it's still compact.
As slinkey alluded to, a smaller charger spinning faster to create the same boost as a larger one spinning slower is going to create more heat, etc, which means less power, increased risk of detonation, blah blah
Depending on boost levels, I'd recommend an SC12 if you're even
considering getting up around 10psi, but an AMR500 should be fine for less.
The SC12 came of the 1.6L 4A-GZE Toyota engine, while it's bigger brother, the SC14, came off the 2.0L 1G-GZE Toyota six cylinder. IIRC the 12 and 14 relate to the cc they pump out ( 1200cc and 1400cc per revolution )
I'll try to dig up my boost vs supercharger rpm calcluations which should help
EDIT: Found it!
This is based on running 7 psi ---
(7psi + 14.7psi) /14.7 = boost ratio ( 14.7psi is normal atmospheric pressure )
x by 1/2 engine displacement (i.e 2 cyl fire every rev) this is the volume required per rev
volume required/blower displacement = pulley ratio
7000rpm x pulley ratio = blower speed ( 7000 rpm is your redline )
--- So for a 998cc running 7 psi with an AMR500 which pumps 500cc per rev: --
(7psi + 14.7) /14.7 = 1.476
1.476 x 449 = 736.524
736.524 / 500 = 1.473
7000rpm x 1.473 = 10311 supercharger rpm
So! at 7000rpm your supercharger will be spinning at 10311rpm!
That's getting a little tooo fast for me! So if you want to run any more boost than that, go the SC12
