OK you can go taller by using A+ gears, as PAIRS. Don't mix with the A series gears above, tooth helix angle is different.
DAM2806 wheel, DAM 2808 pinion, 19/61, 3.211:1
DAM6327 wheel, DAM2808 pinion, 19/59, 3.105:1
DAM5925 wheel, DAM5927 pinion, 20/59, 2.95:1
TCB10004 wheel, TCC10001 pinion, 21/58, 2.76:1
BTW all this info is in Mini Car Clinic catalog.
3.1 is supposed to be good, if you find a set.
