need some help..
https://www.ausmini.com/forums/viewtopic.php?f=2&t=39056
Page 1 of 3
Author:  tinymorris1969 [ Thu Dec 27, 2007 6:12 pm ]
Post subject:  need some help..
ok guys a lil while ago i posted about tinys rust problem and a solution has been found :) . a friend of dads is a panelbeater and said he will do the repairs and the respray for me for cheap if i strip the car completely for him which is fair enough.
so heres the question. can anyone help me strip tiny down ready to go to the PB?
everything needs to come out and off, and im not confident in pulling it apart myself so if anyone can give me a hand it be great.
reward....free beer and lunch on the day
Author:  gafmo [ Thu Dec 27, 2007 7:45 pm ]
Tiny to be truthful..Stripping is the easy part its the putting back together which is the hardest part :?
Best thing I can help you with..Get a Bot of Zip lock bags and a Permanent Marker. Few Boxes to place Interior stuff into..etc
You will learn many things about a Mini when stripping one down :wink:
Author:  Hanra [ Thu Dec 27, 2007 7:52 pm ]
What happens when a customers car comes into the workshop and has to have parts pulled off it?
Author:  gerg [ Thu Dec 27, 2007 7:52 pm ]
Joe, I'd love to be able to have the time to help out,( god know's I love to take things apart... :twisted: ), but as you can tell I'm in the middle of my own project at the moment, and I am finding it hard to find the time for that.... :( . Which ever way you go about the strip down make sure you make this the most important thing, get as many containers as you can , a roll of masking tape and a good marker and make sure you lable every part ,every wire and all of the other little bits that you remove from Tiny. I know what your saying about now, but believe me it makes it soooooo much easier when the time comes to put it back together...oh, and BTW good luck mate :D
Gerg
Author:  Blokeinamoke [ Thu Dec 27, 2007 8:10 pm ]
Post subject:  Re: need some help..
once you have done it you will be confident enough to do the next one- the only way any of us work out how do stuff - is to do stuff. Enjoy :D
Author:  Besser [ Fri Dec 28, 2007 9:33 am ]
Post subject:  Bolt bloke
If your not confident pulling it apart your not going to get it together. So suck it up and be confident you can do it (Bob)
Get a good workshop manual
Get some tools
Get lots of WD40 for the stuck bolts/nuts
Use a digital camera during the process to record tricky areas!
Once apart take each bolt down to a bolt place and get them replaced (also record where they cam from and the replacement spec, then post the list and be loved by every ausmini member)
Heaps of luck and don't give up
Author:  mini-dunger [ Fri Dec 28, 2007 10:04 am ]
i have got boxes apon boxes with permanent marker scribbled all over it. ice cream containers, cut off coke bottles crap everywhere. It was a bit of over kill really. Being a mini there is not really all that much to take off. Strippin is really easy.
Author:  tinymorris1969 [ Fri Dec 28, 2007 6:31 pm ]
i know what everyone is saying and its true, ill have an attempt at it i juz thought it would be a good way for all the ausmini members in sydney to get together and at the same time strip the mini down.
the plus side is ive got tiny registered again so i can start driving it again and when the guy is ready for the car ill strip it down.
Author:  Blokeinamoke [ Fri Dec 28, 2007 6:36 pm ]
so you dont need help - well you do but it might not be in the way you think :P
Author:  tinymorris1969 [ Fri Dec 28, 2007 6:39 pm ]
r u hinting to help there biam??
Author:  Blokeinamoke [ Fri Dec 28, 2007 6:41 pm ]
um maybe - but only if you do most of it yourself - I will help if you get stuck.
Do you have a manual for your car?
Author:  tinymorris1969 [ Fri Dec 28, 2007 6:42 pm ]
i have 2 but toasted has borrowed one so i need to get that back asap
Author:  gafmo [ Fri Dec 28, 2007 6:44 pm ]
Yep I can understand having a BBQ and Beer for a few of us around :wink: with some stripping....Brunetts please
Author:  Mike_Byron [ Fri Dec 28, 2007 6:46 pm ]
Joe
Do me a favour and tell me where this rust is and how bad is it ?????
You dont need a bare body shell to repair rust unless the shell is so badly rusted that its about to fall apart.
have you understood the panel beater correctly ?? Are you sure he just doesn't want all the trim etc out of the when he is working on a particular area. All of a sudden you are turning rust repairs into a two year restoration project.
Mike
Author:  tinymorris1969 [ Fri Dec 28, 2007 6:47 pm ]
lmao, sure thing gaf.... id appreicate it if anyone could help and like i said it would be a sorta day event thing with all the members of ausmini in sydney if possible
Page 1 of 3 All times are UTC + 10 hours
