A good trick to positioning the exterior A-panel before welding it on to put bolts through the 4 holes, it makes it very easy and you can get away with a lot less clamps than you would to hold it on without the bolts.
For example.
Another good trick that I've been taught is to strengthen and seal off the hinges with little triangle cut outs. I forgot to take pics off the car, but I'm doing the otherside at the moment so I'll take some more pics.
Basically like this. Next step on that is to use some silicone seam sealer then cover in undersealent to make it look nice.
In the pics above you can see where some "cutting and shutting" needed to be done to the inner A panel to remove the smal holes and lots of rust pitting. The replacement steel was zinc coated 1.6mm steel, whilst the outer A panel was made from 0.88mm steel, I think.
1977 Leyland Mini LS - Project LS-T
