It is currently Mon Jul 28, 2025 7:00 pm
 Post subject: Fuel starting issues
PostPosted: Wed Feb 13, 2008 2:55 pm
HI guys,
just a quick question. in the mornings my clubman takes a lot of cranking to start. The battery is really strong. but seems like fuel issue. as you can't smell fuel.
then for the rest of the day the mini starts in a bout 2 or 3 seconds. but the longer you leave it parked ie don't move it all day when you get to work it takes a bit longer.
Could the fuel pump be gone allowing fuel to drain back to the tank??
Any ideas??
Cheers Brett
PostPosted: Wed Feb 13, 2008 3:21 pm
Put an electric pump in. Easy. 8)
Also, make sure your choke is open completely when pulled right out.
PostPosted: Wed Feb 13, 2008 3:24 pm
When it's cold, pull the float bowl lid off and see how much fuel is in there. If the fuel pump is a problem, there wouldn't be any fuel in there. I would think it isn't the fuel pump, as fuel can't flow back out of the float bowl once it is in there, unless it is overflowing.
Personally I would check that the choke is fully operational.
PostPosted: Wed Feb 13, 2008 4:39 pm
I agree with Anto. It does not sound like a fuel pump problem. The carby should be full of fuel even after a week.
Now if the pip on the jet on the bottom of the carby is cracked or if the O-ring is leaking it could cause it to be slow at starting.
 Post subject: Fuel
PostPosted: Wed Feb 13, 2008 5:09 pm
I also had this problem with my su, my problem was the choke wasn't working correctly.
As soon as i adjusted it correctly it started straight away when it was cold.
Steve
Classic Not Plastic
PostPosted: Wed Feb 13, 2008 6:30 pm
Check your points gap.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Wed Feb 13, 2008 7:01 pm
thanks guys will check it out over the weekend
:lol:
