It is currently Mon Aug 18, 2025 4:50 pm
 Post subject: Mini gutter trim
PostPosted: Fri Feb 15, 2008 5:24 pm
i just have a question about this item...
http://cgi.ebay.co.uk/Black-Roof-Gutter ... dZViewItem
does this go around the outside of the gutter on the roof or is it for the inside of the car?
PostPosted: Fri Feb 15, 2008 5:32 pm
It goes around the outside like this one
http://www.minisport.com.au/prod213.htm
I'm pretty sure one of the local shops will have one if you'd rather not ship internationally.
PostPosted: Fri Feb 15, 2008 5:42 pm
Does it clip over the existing rim or do you remove the existing rim and tack up the new one to the body?
would rather buy it internationally as it is alot cheaper. figures though hey
PostPosted: Fri Feb 15, 2008 5:43 pm
Where can I get the metal silver one for Sal's roof?
1978 Leyland Mini 998LS All Original *Sally*
2002 Mini Cooper *Coopa*
PostPosted: Fri Feb 15, 2008 5:44 pm
hey
check ebay.co.uk for the metal ones
they are way cheaper
search under mini guttet trim
PostPosted: Fri Feb 15, 2008 7:01 pm
Yeah ebay or Mini Spares.
Locally though I've found Minisport excellent to deal with even if they are more expensive than the poms
As far as fitting them. I haven't got a set myself but I'm fairly certain they just clip on like the side trim
PostPosted: Fri Feb 15, 2008 7:26 pm
yeah, it clips over the standard roof gutter... I've seen some rovers with horrid looking gutter lips from the factory, so I can see why the trim over the top is necessary
PostPosted: Fri Feb 15, 2008 8:51 pm
These trims were only used on later UK cars without the so-called `drip rails' (which don't really.. :lol: )
Will they fit with drip rails, or not?
PostPosted: Fri Feb 15, 2008 9:10 pm
not sure im going to send them a email to see if it clips on a existing drip rail.
PostPosted: Fri Feb 15, 2008 9:43 pm
I got some of the chrome look plastic gutter trim on my car. Looks really good on the right car. Compliments the chrome look wheel arch trim.
Just some hot water and put it on. Came with a little chrome clip to cover the gap when the two ends meet (although some kid flogged it off my car, probably because it was reachable and shiney :roll: ).
Users browsing this forum: No registered users and 321 guests
