Mini gutter trim https://www.ausmini.com/forums/viewtopic.php?f=2&t=39270 |
Author: | lilmatti_69 [ Fri Feb 15, 2008 5:24 pm ] |
Post subject: | Mini gutter trim |
i just have a question about this item... http://cgi.ebay.co.uk/Black-Roof-Gutter ... dZViewItem does this go around the outside of the gutter on the roof or is it for the inside of the car? Cheers |
Author: | Daniel Butler [ Fri Feb 15, 2008 5:32 pm ] |
It goes around the outside like this one http://www.minisport.com.au/prod213.htm I'm pretty sure one of the local shops will have one if you'd rather not ship internationally. |
Author: | lilmatti_69 [ Fri Feb 15, 2008 5:42 pm ] |
Does it clip over the existing rim or do you remove the existing rim and tack up the new one to the body? would rather buy it internationally as it is alot cheaper. figures though hey |
Author: | Beefa [ Fri Feb 15, 2008 5:43 pm ] |
Where can I get the metal silver one for Sal's roof? |
Author: | lilmatti_69 [ Fri Feb 15, 2008 5:44 pm ] |
hey check ebay.co.uk for the metal ones they are way cheaper search under mini guttet trim |
Author: | Daniel Butler [ Fri Feb 15, 2008 7:01 pm ] |
Yeah ebay or Mini Spares. Locally though I've found Minisport excellent to deal with even if they are more expensive than the poms As far as fitting them. I haven't got a set myself but I'm fairly certain they just clip on like the side trim |
Author: | simon k [ Fri Feb 15, 2008 7:26 pm ] |
lilmatti_69 wrote: Does it clip over the existing rim or do you remove the existing rim and tack up the new one to the body?
would rather buy it internationally as it is alot cheaper. figures though hey yeah, it clips over the standard roof gutter... I've seen some rovers with horrid looking gutter lips from the factory, so I can see why the trim over the top is necessary |
Author: | drmini in aust [ Fri Feb 15, 2008 8:51 pm ] |
simon k wrote: lilmatti_69 wrote: Does it clip over the existing rim or do you remove the existing rim and tack up the new one to the body? would rather buy it internationally as it is alot cheaper. figures though hey yeah, it clips over the standard roof gutter... I've seen some rovers with horrid looking gutter lips from the factory, so I can see why the trim over the top is necessary These trims were only used on later UK cars without the so-called `drip rails' (which don't really.. ![]() Will they fit with drip rails, or not? |
Author: | lilmatti_69 [ Fri Feb 15, 2008 9:10 pm ] |
not sure im going to send them a email to see if it clips on a existing drip rail. |
Author: | slinkey inc [ Fri Feb 15, 2008 9:43 pm ] |
I got some of the chrome look plastic gutter trim on my car. Looks really good on the right car. Compliments the chrome look wheel arch trim. Just some hot water and put it on. Came with a little chrome clip to cover the gap when the two ends meet (although some kid flogged it off my car, probably because it was reachable and shiney ![]() |
