It is currently Wed Aug 20, 2025 11:06 am
 Post subject: Alloy Mini Radiators
PostPosted: Fri Feb 15, 2008 7:26 am
I notice there are more alloy radiators cropping up on Ebay. I notice on this one:
Alloy Radiators on Ebay
That it has the smaller type of radiator cap, from a modern car. As far as I knew, these caps are not available to suit a car fitted with no overflow tank (ie a Mini). All the caps of that size I have seen available, have been the type to suit a car with a non-pressurised overflow tank. Does anybody know if the cap will actually work?
I will not pass judgement on the asking price.
PostPosted: Fri Feb 15, 2008 2:30 pm
Don't know about the cap, but, the radiators sure do look nice.
PostPosted: Fri Feb 15, 2008 3:37 pm
High heel ninja
Mini spares in Sydney have alloy radiators, i belive they take a normal mini sized cap.
Doogie
PostPosted: Fri Feb 15, 2008 6:45 pm
Give Ash some flowers Nick .
They look nice - very bling bling 8)
PostPosted: Fri Feb 15, 2008 8:05 pm
I can't imagine why the radiator cap would be any problem, as long as it is the right lifting pressure.
 Post subject: Re: Alloy Mini Radiators
PostPosted: Fri Feb 15, 2008 8:16 pm
I'm with you Anto - looks like a plain cap with no springy bit inside
PostPosted: Fri Feb 15, 2008 9:27 pm
I think you'll the cap is the type which is designed to allow the coolant to evacuate above a certain pressure, but once the pressure goes down it sucks the coolant back in - ala non pressurised overflow tank. With a Mini it is only designed to evacuate coolant above a certain pressure, but not draw it back in.
PostPosted: Fri Feb 15, 2008 9:38 pm
That's not really a big deal. Most new cars use the draw back system and many, many different non-pressurised expansion tanskc an be source cheap from your local generic car wrecker.
Ideally, a blank off cap would be the way to go, and then use a pressurised expansive tank. Preferably alloy too for extra bling, or polished brass like my car.
PostPosted: Sat Feb 16, 2008 6:49 am
There is a standard cap you can get that fits Mini rads and allows this, just watch the length as there are 2 (Oz and UK).
For UK rads, and non pressurised overflow tank, use a `CPC’ 543-13, made in Oz. I ran one on a super 2 core rad.
PostPosted: Sat Feb 16, 2008 8:29 am
what pressure should a mini radiator cap be??
For Australian Cooper S running a ST 2 core radiator from England??
PostPosted: Sat Feb 16, 2008 8:48 am
Yes but the 543-13 is a large diameter cap. My point is, this alloy radiator has the small diameter cap, which as far as I know is only available as either a blanking cap (for pressurised overflow tank) or for non-pressurised overflow tanks. I don't think it is available for use of cars with no overflow tank.
PostPosted: Sat Feb 16, 2008 12:57 pm
I have alloy radiators in stock here but they don`t cost anywhere near that much
PostPosted: Sat Feb 16, 2008 1:34 pm
Can someone explain if there would be a need for a different cap in that case. The end result would simply be it lets air back into the top when the tank has overflowed, isn't that what happens anyway ??
PostPosted: Sat Feb 16, 2008 1:42 pm
Just run a cap for an overflow tank, the radiator will not know the difference.
PostPosted: Sat Feb 16, 2008 2:12 pm
miniman how much are your alloy rads. could you post a pic of what they look like.
cheers dan
Cheers Dan
Users browsing this forum: Bing [Bot] and 96 guests
