Should I get a thermo fan.
https://www.ausmini.com/forums/viewtopic.php?f=2&t=39313
Author:  mini-dunger [ Sun Feb 17, 2008 12:59 am ]
Post subject:  Should I get a thermo fan.
Hi all.
I was just wondering if I should fit a thermo fan to my engine?.
I have had the radiator cut up and cleaned and the blocks been hot tanked. I need to buy a new fan anyways and the cost is about the same for a new fan as it is to get a SH thermo of a late model car.
Would it be fairly easy to wire the thing in with a sender etc etc?
thanks guys.
Author:  Drekkus [ Sun Feb 17, 2008 8:03 am ]
I have a thermo fan on my car as a backup on hot days ( a new or reconditioned radiator would probably help as well).
Its wired in at the moment via a relay and switch so the wiring isn't too hard, you just have to remember to watch the temperature so you know when to flick the switch.
I do have the sender but nowhere to put it at the moment and that would require a little bit more thought on the wiring but still shouldn't be too hard.
38 today so it probably will get a work out today :D
Author:  buztoy [ Sun Feb 17, 2008 9:35 am ]
get the thermo, on the highways its alot more quieter seeing you dont have it wirring away at 4000rpm,
i also put it on the same fuse so if the fuse for the fan blows the engine will cut out,
and seal round the side of the fan, i went without the switch and it warmed up in 3mins of carefull slow and easy driving
