It is currently Fri Aug 15, 2025 10:13 pm
PostPosted: Tue Feb 19, 2008 7:03 am
Hi all
I have a problem removing 1 of the locating bushes that goes between the steering arm & the swivel hub.
Tried penetrene for a couple of days. Wont budge.
Any suggestions?
Thanks
1967 Morris Mini Deluxe
1927 Austin 7
PostPosted: Tue Feb 19, 2008 9:07 am
Not having a go at you but do you mean ball joint? I'm not aware of a locating bush......
PostPosted: Tue Feb 19, 2008 11:03 am
Sounds like he`s talking about the steerring arm "Dowels"
heat with an oxy set & maybe grab with Vice grips & twist,,,
Why do yoiu want to get it out anyway??? If it`s stuck nice & hard like that then i reckon it`s a good thing, don`t disturb it
If it`s damaged then ok,,, rip it out & buy new ones & locktite them in because the last thing you would like is your steering arms comming adrift,,, not pretty results
PostPosted: Tue Feb 19, 2008 11:08 am
Thanks for you ideas.
Yes they are the steering arm dowels.
You cant buy any replacement (that Iam aware of. Tried a few places). Would have to make them.
I will leave it in.
One is a bit scored. Will dress with a file.
Thanks
1927 Austin 7
PostPosted: Tue Feb 19, 2008 11:11 am
There are 2 hollow locating pegs in the top of the hub that locate the steering arm. They do come out because sometimes they will come out attached to the arm and sometimes they stay in the hub. I have never had a reason to pull one out though.
If the holes don't go all the way through (can't remember) you could put some grease in the hole and find a rod (bolt?) that is a good fit inside and give it a whack with a hammer. The grease should compress and force the peg out (hopefully). Might be messy.
Pete
PostPosted: Tue Feb 19, 2008 11:12 am
Damn, I'm too slow.
Users browsing this forum: No registered users and 167 guests
