Mick wrote:
britishvita wrote:
After sandblasting get it primed in epoxy 2 pak immediately that will keep it safe from the elements, then do any bodywork etc etc.
Will that need to be removed as time goes on before the final primers and paint coats??
Epoxy 2 pak primer will protect it from the elements (something like PPG DP40), I've heard of people leaving their car out in DP40 for quite a few years and its still fine - warning though it isn't UV stable so needs to be covered by a tarp or something else. Cost is about $330 for 6 litres worth...
Once the body work is all done you can roughen up the epoxy with 240 grit paper and apply filler (bog) to the epoxy then 2 pak hi-fill primer and then a sealer coat of epoxy then base coat and clear coat. I'd also clean the epoxy before sanding too with something like window cleaner and wax and grease remover
The cheaper option is etch primer but it can let moisture etc in but if the car is all straight and you don't need to apply filler you could coat the etch with 2pak hi-fill and then it should be moisture resitant.
BTW Mick how's your resto going, haven't seen an update for a while (although I can't talk mine hasn't been updated for ages
