mini van battery location https://www.ausmini.com/forums/viewtopic.php?f=2&t=39412 |
Author: | blueminivan [ Tue Feb 19, 2008 5:43 pm ] |
Post subject: | mini van battery location |
G'day all. I'm fitting the battery into my van for the first time and I'm wondering where the earth is supposed to connected to the body. Do I just bolt the earth to the battery support panel or is there a better way of doing this? Is there meant to be a tray, and how's it meant to be anchored down? I'm using a sealed battery so next to no chance of a leak I hope. Some pic would be great guys!! ![]() I've looked through all my mags but can't get a good pic of behind the seats. ![]() |
Author: | simon k [ Tue Feb 19, 2008 8:19 pm ] |
it was originally anchored by a strap that went around the battery, the remnants of mine are still there at either end, it looked like a stretchy fibre sort of thing... the earth went into the floor just beside the vertical support panel. |
Author: | bnicho [ Tue Feb 19, 2008 8:57 pm ] |
My van had a folded metal strap like a Mini sedan uses. The hold-downs went throught this and down on a 45 degree angle to holes in the support behind the battery just off the floor. Same way the battery is secured in my Moke. The elastic strap just held on a cardboard cover. No tray was used, so I borrowed one from a Gemini at the wreckers. I'm pretty sure the earth cable screwed into a captive nut in the centre support between the upper floor and the tunnel. But it was a few years ago, so my memory may be soggy. In the end I used a slimline DIN53L battery and moved it back into the "dead space" under the upper load floor with a hatch for access. That way I could move the seat back a couple more inches. |
Author: | blueminivan [ Tue Feb 19, 2008 11:05 pm ] |
Thanks for the info guys. I'll play around and see what I come up with. Cheers. |
