It is currently Wed Aug 13, 2025 1:34 pm
PostPosted: Wed Feb 20, 2008 6:27 am
Does anyone know how you can tell if the hydrolastic is stuffed or just needs to be pumped up?
How can you tell is it is leaking?
Also if it is leaking can it be repaired and what cost?
I am looking at mini with hydro and don't want to buy an huge repair bill.
Matt
67 Deluxe under going full resto
PostPosted: Wed Feb 20, 2008 6:42 am
You pump it up then check for leaks around the hose connections, under the hydro `boot' rubbers and particularly at the 2 fill valves in the back. These are just normal Schrader tyre valves, change if they leak.
If it's always had pressure in they don't give much trouble- mine are now 38 years old and counting... :lol:
If you buy the car I would dump the old scungy fluid by letting it out, and refill each side by pumping up with fresh. As long as you don't dismantle anything this will NOT let air in.
PostPosted: Wed Feb 20, 2008 11:12 am
Thanks Dr. You don't own a hydro pump do you?
Users browsing this forum: No registered users and 192 guests
