It is currently Wed Jul 23, 2025 6:40 am
PostPosted: Fri Feb 22, 2008 6:11 pm
Hello, I'm trying to find someone who has a similar setup as described,,,To see what needles you are running in twin 1.5's??? Trying to get the needle selection right or a starting piont...Cheers!!
PostPosted: Fri Feb 22, 2008 6:43 pm
what size motornd i'm sure you have asked GR
PostPosted: Fri Feb 22, 2008 6:51 pm
Its a cooper 's',,1330...and yes asked GR,,,currently trying what was recommended,,ABD needles..and am having the problem of thats in my sparkplug post. Just thought someone would have something similar.....to get a comparison on a needle chart..Cheers!!
PostPosted: Fri Feb 22, 2008 6:52 pm
PostPosted: Fri Feb 22, 2008 6:57 pm
PostPosted: Fri Feb 22, 2008 10:27 pm
im running BG's in mine and have had to screw the jet tubes down a fair way (about 60" i think ....memory fades after working on 1 to many in a day) mines only a 1293 with hepolite pistons, balaanced bottom end a wade 176 cam grind (by clive cams) and tickled metro head with slightly bigger valves (have to find my parts list to check size....hmmmm now where have i miss placed it?), bullet nosed guides, lcb extractors. anyways mine ie running a little to lean still i think....
PostPosted: Fri Feb 22, 2008 10:36 pm
Thanks Ballistic,,Ive heard a few people running..number 6,and cp4,.Selecting the right needle is fun and games..but should be worth it in the end...Thanks for your input..
PostPosted: Sat Feb 23, 2008 7:15 am
Our 1293 with twin HS4s, Corolla rockers like yours, same filters (Ramflo/Unifilter) and similar cam (Wade 104) draws a straight line on the A/F ratio on the dyno at 13.0:1. 8)
Needles are #6. These are fixed needles, I hate the swing ones- they wear your jets. :x
