It is currently Tue Jul 01, 2025 12:51 pm
 Post subject: alternator question
PostPosted: Sat Jul 26, 2008 9:27 am
Hi all
I have just stuck my alternator back in and it doesnt appear to be charging.
I have tried moving the wires about (well the thick one anyway)
I have only 2 wires alocated for the alternator(a big fat one, and a smaller one)
as the 2 heavy brown wires have been soldierd together at the alternator and at the starter relay by the PO.
Why would someone do this?
I am planning on converting it to another type of alternator if I cant fix it.
Lastly is there a way of testing an alternator other than checking the V at the battery?
thanks guys
blokeinamoke wrote:
PostPosted: Sat Jul 26, 2008 9:59 am
Provided its a internally regulated alternator you should ideally have the B+ charge wire, a switched 12v supply that comes from your ign through your charge IND light on the dash, and possibly a voltage sense wire that taps onto the B+ wire. Whats written on the alternator, B+, D+, F????
