clutch housings is there a difference between these two
https://www.ausmini.com/forums/viewtopic.php?f=2&t=39584
Author:  Boostedmini [ Mon Feb 25, 2008 7:26 am ]
Post subject:  clutch housings is there a difference between these two
Hi all,
Apart from one not having the breather, does anyone know if they can be interchanged?
they are different is a few areas, one being where the oil is fed into the bearing on the idler gear.
thanks
Author:  drmini in aust [ Mon Feb 25, 2008 7:40 am ]
Grant,
There are variations in the A series 4 synchro ones with breathers on too, there were a few different baffles used to minimise oil being thrown up into the breather.
The last of the non-breather ones had the same idler bearing size as these, and could be used instead. But as you can see there is little oilfeed provided to the idler bearing.
I would always use the breather one, on a 4 synchro box.
If you need any housings with breathers, come see me as I have a fair selection.. :wink:
