It is currently Fri Jul 25, 2025 10:09 pm
PostPosted: Tue Mar 11, 2008 6:07 pm
I have done a few research and come up with 3 brands of engine oil that I should be using for the following engine: Year 1994 1275 Automatic running a carbie. Following are the brands and grade for engine oil recommended: castrol Magnatec 10W40 or GTX2 20W50? Penrite HPR10? Shell Helix Super 20W50 or multigrade 20X50? Please vote at your best knowledge and thank you once again for your input.
PostPosted: Tue Mar 11, 2008 6:15 pm
Slow-Po
I've had 3 matics on the road- a Morris 1100 auto, a Morris 1300 auto, and 998 MiniMatic. All 3 are basically the same box.
The factory MiniMatic handbook (1969) says-
"SAE 10W/30, 10W/40, or 20W/50. Additional additives are NOT to be used under any circumstances".
I'd stick with 20W/50 in an old box, as the oil does get pretty hot. If running 10W/30 I'd want a cooler on it. :wink:
Don't run semi-synthetics like Castrol Magnatec 10W/40 etc, the bands and clutches won't grip.
That eliminates one of your options. I'd go with K-Mart KMX or Valvoline 20W-50. Like I recommended before, do a search, there is heaps on here that will help you make up your mind. 8)
PostPosted: Tue Mar 11, 2008 6:17 pm
Stay away from grades with anti-wear additives, this means don't use Magnatec. It's a good oil but not in an automatic, the plates and bands will slip.
My original drivers handbook for a Mini automatic says use 10W/40 or 20W/50 grades, with NO antiwear additives.
Any good name brand 20W/50 will do out here.... it's hot. :lol:
PostPosted: Tue Mar 11, 2008 6:26 pm
The handbook for the 1100 Automatic says...
Automatic Transmission---- 10w/30 or 10w/40 multigrade MS oil.
Use no additives. Do not exceed recommended change period.
I would go with what the doc says. These boxes get a workout.
PostPosted: Tue Mar 11, 2008 6:38 pm
I would change it every 1500 miles, the filter too. Most failures in these boxes are due to dirty oil.
Cheap 20W/50 changed often is better than exxy oil left in too long.:wink:
Users browsing this forum: No registered users and 112 guests
