Mike_Byron wrote:
Shard
No !!!!!!
Again, a hydraulic system needs to be sealed to pump fluid. Now, nip up the things you are calling the MC bleeder. Squeeze the pedal slowly, wait a second or two and release the pedal - do this a couple of times and then undo the thing you are calling the bleeder on the MC. DO this with pedal down.
You will get fluid !!! Doing it your way you are pumping the fluid out and then sucking it back. Now nip it up again.
Now, that we know the MC is working - go to the bleed nipple on the slave. Undo it so that you know it undoes and then does up. Nip it up again.
Repeat the slow pump as described above. With the pedal pressed down, undo thje slave bleed nipple to let out the air and traces of fluid and then nip up. Repeat until no more air is being expelled and that the clutch throw arm is moving properly.
Do it my way and then tell me the outcome.
Mike
I don't have a bleeder on the MC. I tried using the slave bleeder on the top where the metal pipe comes out.
If I hook everything up properly so it's a closed system, I still can't get the MC to pump anything out of the reservoir (not even a little bit of fluid with a ton of air).
If I hook up my hose with valve to the slave bleeder and open it a bit, I get no fluid but I get a bit of air pressure because it makes an air pop noise when I remove the hose.
