Disk brake assembly question
https://www.ausmini.com/forums/viewtopic.php?f=2&t=39938
Author:  henry the mini [ Sat Mar 08, 2008 10:49 am ]
Post subject:  Disk brake assembly question
Hello all. Here is a Noob question. I took the wheel off this morning to remove a stone from the stone guard :shock: :shock: , and i notice when the wheel was off that there is a bit of play in the disk drive assembly. It's moving a bit but not too much.
Also the big nuts (Front Hub Nut???) that hold everything together seem to be a bit loose, is it suppose to be like that or should the CV nut be really tight??
Help, please, dont want to kill myself :?
Author:  rampage101 [ Sat Mar 08, 2008 11:03 am ]
The hub nut on disk brakes should be done up to 150ft/lbs, which means yours is a long way undone. Does it have a split pin through it? When you mean movement, you mean you can grab the disc and pull backwards and forwards (like removing the wheel and putting it back on)
Author:  Blunder [ Sat Mar 08, 2008 11:04 am ]
Post subject:  not good..............
The wheel nut tightens the bearings up so thats why there is play! so tighten it up! quick! :shock:
Author:  henry the mini [ Sat Mar 08, 2008 12:06 pm ]
Yep it has a split pin. It doesent really goes backwards and fowards more side way, but again i dident try to pull it :shock:
Off to have a better look :shock: :shock:
Author:  henry the mini [ Sat Mar 08, 2008 8:04 pm ]
Ok had a good look! I could remove the nuts with my bare hands :shock:
Tight them to 120psi or as close as i could get with making shure the split pin could go back in.
Now, the steering is not ratteling anymore :D :D , could this have been the cause?
Thanks you so much....
Author:  rampage101 [ Sun Mar 09, 2008 6:18 am ]
Yep, that would do it, cos the wheel is almost directly connected to the steering wheel.
Author:  drmini in aust [ Sun Mar 09, 2008 6:25 am ]
Henry, you need to tighten that hub nut more, 120 is not enough.
Tighten nut to 150lb/ft torque, then MORE until the pin will go in the next slot. :wink:
Author:  rampage101 [ Sun Mar 09, 2008 7:36 am ]
This reminds me I must do that to mine once I get either the engine in or the wheels on the ground properly :shock:
Author:  Archangel007 [ Sun Mar 09, 2008 7:58 am ]
Doc,
One would think with the nut being that loose for a while and the fact the bearings werent seated against the races as per design, that the bearings might need to be inspected, and perhaps replaced as a matter of caution.
Bearings flog out super quickly when they have a chance to move away from the races.
At the very least removal, inspection and repacking!
Tricky
Author:  henry the mini [ Sun Mar 09, 2008 8:17 am ]
Sorry Doc misspell, they are very close to 150psi..
