Newbie needs help rebuilding mini
https://www.ausmini.com/forums/viewtopic.php?f=2&t=3995
Author:  zello [ Thu Jan 13, 2005 11:11 am ]
Post subject:  Newbie needs help rebuilding mini
Hi
I'm trying to rebuild an old mini and am having problems getting the engine to start. The problem seems to be from the carburettor onwards (as opposed to fuel line/pump problems). I have tried pouring fuel into the carbie, and it does get through to the engine but it still will not start. I have checked the spark plugs and distributor and they are working fine. There is a slight loss of pressure in two of the cylinders but been told that this would not be the source of the problem.
can anyone help?
Author:  Wombat [ Thu Jan 13, 2005 11:16 am ]
Check the timing - rotor in the distributor pointing to 2 o'clock with #1 cylinder TDC and flywheel timing marks at 1/4
Author:  Harley [ Thu Jan 13, 2005 11:33 am ]
Whether it is obvious or not, check you have good fuel, mot what was left in it 30 years ago.
Author:  1380 yellow devil [ Thu Jan 13, 2005 11:56 am ]
I would go with checking the timing on the dizzy like said make sure rotor button is at #1 Cylinder lead when #1 is on compression stroke.
Author:  mutant mini [ Thu Jan 13, 2005 12:11 pm ]
Put your suburb in the profile and maybe someone living close by could have a look at it for you.
