It is currently Sun Jul 20, 2025 10:00 pm
 Post subject: Whats this?
PostPosted: Mon Mar 10, 2008 11:58 am
Hey after recently stripping my interior i noticed that this wasnt being used for anything? i pritty sure it was just laying there under the carpet near the handbrake.
what is it and does it go anywhere?
Thanks
PostPosted: Mon Mar 10, 2008 12:02 pm
light switch from the door
PostPosted: Mon Mar 10, 2008 12:08 pm
u mean the switch that makes the interior light go on when the door is open?....both my driver n passenger door have one...
any other ideas?
PostPosted: Mon Mar 10, 2008 12:13 pm
Sounds like may be a handbrake warning light switch ... fitted to late clubmans.
If so, there should be a square warning light in the dash padding...
PostPosted: Mon Mar 10, 2008 12:17 pm
is it connected to anything as it could be a spare or the handbrake as suggested
PostPosted: Mon Mar 10, 2008 12:18 pm
hey yea i have a 78 clubman.... and i do have the warning light, Park Brake....would you know where and how to connect this....it cant just lay there can it?
PostPosted: Mon Mar 10, 2008 12:19 pm
nah it was just laying there near the handbrake.
PostPosted: Mon Mar 10, 2008 12:38 pm
It' been a while since I've had a late clubman...
but if memory serves there is "tab" that sticks out from the side of the handbrake lever... and a corresponding bracket bolted to the floor in which the switch should push into...
The tab would then push againt the switch turning on or off appropriately.
You should be able to test the switch to see if it works just by pushing in and out. (with igintion on)( ? may have to earth it against something metal ?)
But short answer - don't need it - all it does is light up the warning light.
