Ball Joints
https://www.ausmini.com/forums/viewtopic.php?f=2&t=40106
Author:  Bfeboi [ Wed Mar 12, 2008 7:18 pm ]
Post subject:  Ball Joints
Ok ppls.
I bought myself a 4 pot KAD disk brake kit. i managed to build all the hubs ok but am stuck on the ball joints.
i'm following the haynes workshop manual. it tells me to place the shims on top of the lock washer but when i looked into the kit i only had a total of 6 shims (3 pairs). when i fit 3 shims into the top ball joint (no spring) and tighten the nut the ball stud is pretty much solid in movement. then i add the other 3 shims (6 in total) the ball stud is very notchy. is this because its new or is there something im doing wrong?
i'd post pictures but i can't get the pics out of my phone at the moment
Any help will be appreciated
Author:  Bfeboi [ Wed Mar 12, 2008 7:19 pm ]
wtf why are my T/H/E turning into teh?
Author:  Mick [ Wed Mar 12, 2008 7:22 pm ]
It's a problem we're working through at the moment.
The new ball joint kits always seem to come with only a few shims, never enough. Try to save your old ones if you can find any amongst the old ball joints.
Author:  Bfeboi [ Wed Mar 12, 2008 7:51 pm ]
but how should the ball joint feel when fully assembled??
cos im an apprentice the ball joints on the european cars i work on are tight when new but roll around smooth later.
does it flow smooth or a bit notchy?
Author:  drmini in aust [ Wed Mar 12, 2008 7:52 pm ]
When torqued up to 72 lb/ft, you should just be able to move it by hand. it will be a bit notchy.
Author:  Mick [ Wed Mar 12, 2008 7:54 pm ]
You can lap them in with some valve grinding paste to make them a little smoother before adjusting them up if you like, or they will smooth up in use.
Make sure the socket and cup is nice and clean and adjust them up without any grease and also without the spring on the upper ball joint.
Author:  rampage101 [ Wed Mar 12, 2008 8:13 pm ]
Isn't the spring on the lower?? :shock:
Author:  Bfeboi [ Wed Mar 12, 2008 8:16 pm ]
when u say adjusting are you talking about getting the right amount of shims needed till the ball stud is difficult to move?
i would've thought that it needed to move
obviously im a mini newb :oops:
Author:  gafmo [ Wed Mar 12, 2008 8:18 pm ]
Yes....I hope you didnt throw out the old shims
Author:  Mick [ Wed Mar 12, 2008 8:21 pm ]
I forget....one or the other...ummm..
Still, leave it out anyway is the rule while adjusting shims, it upsets the amount of shims you will need by pushing the ball harder into the cup.
Author:  Bfeboi [ Wed Mar 12, 2008 8:22 pm ]
nah the old drum and hubs are at home and the KAD kit arrived at my work.
all the mechanics crowded around as i opened the boxes. Like bugs to a bright light 8)
Author:  drmini in aust [ Wed Mar 12, 2008 8:23 pm ]
Yep the spring is on the bottom one. Adjust it without, then fit the spring.
Author:  rampage101 [ Wed Mar 12, 2008 8:28 pm ]
Yeh, not long ago went through all this, was a right ning nong, mainly becuase you have to torque every time!
The handle of my big ball pein came in handy, good leverage throught the hub against the torque wrench, shame the handle looks like crap now :(
