Crank pulley.....
https://www.ausmini.com/forums/viewtopic.php?f=2&t=40108
Author:  Blunder [ Wed Mar 12, 2008 7:25 pm ]
Post subject:  Crank pulley.....
Whats the best wat to remove pulley bolt when engine is out of the car with clutch/flywheel removed???
Author:  suffolk [ Wed Mar 12, 2008 7:35 pm ]
You could stuff a long piece of rag in the spark plug hole to lock her up...But i would just put the flywheel back on with the cover and put a screw diver thru the starter motor hole and lock it up that way to undo the bolt...Cheers!!
Author:  gafmo [ Wed Mar 12, 2008 7:38 pm ]
I use a wheel bearing race
Author:  Blunder [ Wed Mar 12, 2008 7:38 pm ]
Post subject:  if only....
only got a apart engine, got flywheel but no retaining locator thingy! lol
Author:  Morris 1100 [ Wed Mar 12, 2008 7:44 pm ]
Put a socket on the bolt and give the bar a whack with a block of wood.
Author:  1071 [ Wed Mar 12, 2008 7:46 pm ]
I assume the question is because the engine and gearbox are still attached?
Otherwise just stick a suitable piece (inch and a half square?) of hardwood between the crank and case.
If 1. then maybe a rattle gun?
Cheers, Ian
Author:  simon k [ Wed Mar 12, 2008 7:53 pm ]
feed a bit of rope down the spark plug hole, I've done it a few times, works well ;)
