what is this? 22g250 https://www.ausmini.com/forums/viewtopic.php?f=2&t=40137 |
Author: | marcello [ Thu Mar 13, 2008 2:52 pm ] |
Post subject: | what is this? 22g250 |
i bought this off ebay. it was meant to be 22g440 as the box says but the part inside is different, it has 22g250 stamped on it. it is still a first gear but i dont know what it is from. any help would be greatly appreciated. |
Author: | Morris 1100 [ Thu Mar 13, 2008 5:18 pm ] |
It doesn't come up in any of my books, but I don't have all the books! Not many hits on Google either but one was for a Morris Minor forum. ![]() 22G440 comes up as 1st & 2nd speed sliding hub "A form" gears. 22A1021 comes up as 1st & 2nd speed sliding hub "B form" gears. The Mini books and the Morris 1100 books only come up with these two numbers. I can only come up with two ideas, 1) The part number in the book is different to the number stamped on the part (usually only one digit out, not way out like this) 2) It is out of a RWD Gearbox. |
Author: | suffolk [ Thu Mar 13, 2008 5:42 pm ] |
I looked in a pommy mini parts book and its not in there either,,,but could be a No Longer Available number as they don't list these numbers...Is there anyway you could compare it to other gears...if there the same dimensions and same amount of teeth etc.. Part numbers shouldn;t really matter...Cheers |
Author: | 9YaTaH [ Thu Mar 13, 2008 5:43 pm ] |
Post subject: | Re: what is this? 22g250 |
marcello wrote: i bought this off ebay. it was meant to be 22g440 as the box says but the part inside is different, it has 22g250 stamped on it. it is still a first gear but i dont know what it is from. any help would be greatly appreciated.
Could it be 22G490?? |
Author: | marcello [ Thu Mar 13, 2008 6:34 pm ] |
thanks guys. as morris 1100 suggested. it may be minor. the parts look exactly the same but at the moment i have no way of measuring the finer details, thats why i asked. thanks again! |
