stripped thread question https://www.ausmini.com/forums/viewtopic.php?f=2&t=40178 |
Author: | mini-dunger [ Fri Mar 14, 2008 10:18 pm ] |
Post subject: | stripped thread question |
Hi guys Mr dodgy from dodgy brothers mechanical repairs or the PO had stripped a thread on the drivers side diff case and neglected to 1) tell me 2) fix it it felt strangely loose when I undid it to bolt my xtractors up. So then when I tightened it up I barely clamped the exhaust tab before it just span for a good length of time without moving in the inward direction. I was visiting my local tool guru a while ago and he showed me these high tensile grub screw looking things with a thread on both the inside and the outside that you just screwed in and used a smaller bolt. I think it cuts its own thread. Anyone used em? Failing that I will just tap it out with the next size metric bolt or something. I could put a helicoil in but I would have to pull the cover off. Has anyone else had the pleasure of doing this job? thanks everyone ![]() |
Author: | drmini in aust [ Sat Mar 15, 2008 5:50 am ] |
Now it's stripped the hole is 5/16" diameter, perfect size to tap out to 3/8 UNC. Tap it out, drill the hole in the cover to 3/8, and Bob's yer auntie's husband. ![]() 3/8 thread is harder to strip next time. |
Author: | mini-dunger [ Sat Mar 15, 2008 2:08 pm ] |
drmini in aust wrote: Now it's stripped the hole is 5/16" diameter, perfect size to tap out to 3/8 UNC.
Tap it out, drill the hole in the cover to 3/8, and Bob's yer auntie's husband. ![]() 3/8 thread is harder to strip next time. could I do it with the cover on? provided I drill the cover first? |
Author: | WantOne [ Sat Mar 15, 2008 2:16 pm ] |
Those things the tool guy was talking about are probably called a keen sert http://www.circletrack.com/techarticles ... to_05.html I found one at work yesterday on the floor and had to spend about an hour trying to find out where it was from...... Still haven't worked it out. |
Author: | drmini in aust [ Sat Mar 15, 2008 2:22 pm ] |
mini-dunger wrote: drmini in aust wrote: Now it's stripped the hole is 5/16" diameter, perfect size to tap out to 3/8 UNC. Tap it out, drill the hole in the cover to 3/8, and Bob's yer auntie's husband. ![]() 3/8 thread is harder to strip next time. could I do it with the cover on? provided I drill the cover first? Yes you can, just don't drill too deep.... you just want the cover to be 3/8... ![]() |
Author: | miquain57 [ Fri Mar 21, 2008 10:06 am ] |
Doc, I am about to start my mini project and have been thinking about buying a tap and die set. do i buy UNF or UNC or both?? :-S Thanks |
Author: | Mick [ Fri Mar 21, 2008 10:26 am ] |
You will need both UNF and UNC for the car. Although you can get a few individual ones of each type and not be too concerned with the rest. 1/4, 5/16 and 3/8 in both UNC and UNF will get you through the car no problems on their own. About 80 percent of all the threads you will encounter will be 5/16 UNC or UNF. BTW: If you have a stripped 5/16 UNF thread, you can purchase the helicoil to fix this (about a dollar each from repco or bursons etc) and use a 3/8 UNF tap to prepare the hole for the insert. I believe this is the only size and thread size on a mini you can do this without a specialist tap, but 5/16 is a useful size being the most common. |
Author: | drmini in aust [ Fri Mar 21, 2008 10:32 am ] |
All the gearbox threads are UNC. `Most' engine threads are UNF. The thread you stripped is 5/16 UNC. Just go buy a decent 3/8 UNC 2nd (intermediate) tap, stay away from the crappy cheapo sets. I only buy taps as I need em... ![]() |
Author: | TheMiniMan [ Fri Mar 21, 2008 11:56 am ] |
The general "Rule of thumb" is to use the fine threads in steels ,,, & a slightly longer coarse thread type in alloys Make sure it`s all nice & clean, spray both the new bolt & the tread in the case with lockquick primer & let sit for a while (as on the instructions written on the can of lockquick),,, then a dab of locktite "Nut lock",,, or "thread lock" tighten it up & Bob`s your Aunty ![]() Some guys even drill a small hole in the botl head & use tie wire to make sure that it doesn`t come out even if it loosens at a later date & on my race cars i weld 2x tabs on,,, one on the lower pipe & one onto the uper piece & then use a spring like on a go-kart pipe to make sure that even if the bot falls out then at least the pipe can`t fall off insurance is such a good thing in the long run |
Author: | Wombat [ Fri Mar 21, 2008 12:24 pm ] |
I've got a doggy sump drain hole - original UNC thread has had a UNF thread forced into it and it's missing some bits on the edge. What should I do with it? Here is a picture of the hole and the two plugs I've got. ![]() ![]() |
Author: | drmini in aust [ Fri Mar 21, 2008 12:48 pm ] |
Wombat wrote: I've got a doggy sump drain hole - original UNC thread has had a UNF thread forced into it and it's missing some bits on the edge. What should I do with it? Here is a picture of the hole and the two plugs I've got. I would get a 5/8-11 UNC tap and clean it back out.
![]() ![]() If there are not enough threads left to hold the plug then, I would get it helicoiled. <edit> that other plug looks like a 3/8 BSPT to me, they are about .010" smaller than 5/8. ![]() |
Author: | Timbo [ Fri Mar 21, 2008 7:33 pm ] |
I had one that was stripped, I went to an engineering place and they tapped it for the next size up. They had a rack of sump plugs for that exact job. Cheaper than a helicoil. Tim |
Author: | drmini in aust [ Fri Mar 21, 2008 9:27 pm ] |
We bought one once (in a $20 van) with the casing broken away that had a lump of hardwood bashed in there, it never leaked a drop. ![]() It's an engine stand now.... ![]() Tapping it out to take a standard plug is good, but I'd drill a hole and press or araldite a magnet in there. ![]() |
Author: | Wombat [ Fri Mar 21, 2008 9:43 pm ] |
drmini in aust wrote: Tapping it out to take a standard plug is good, but I'd drill a hole and press or araldite a magnet in there.
![]() I think that is what someone has done with the plug on the left as the magnet can be pulled out of it. |
Author: | drmini in aust [ Fri Mar 21, 2008 9:53 pm ] |
Gentle press fit better lasting than araldite, sitting in hot oilz.... ![]() |
