It is currently Sat Jul 26, 2025 12:54 am
PostPosted: Mon Mar 17, 2008 7:54 pm
One of the bolts that mounts the clutch master to the firewall has fallen out and down into the pedalbox. I am aware they were originally tack welded in place, but mine seems to have decided it liked it better in the car.
Is there an easy way out of this? what a bitch of a job. It's going to be bloody hard to shove a newone up through the hole, get a nut on it and then tighten it up.
PostPosted: Mon Mar 17, 2008 7:58 pm
How about installing it upside down.
If the bolt is facing down you could brace a spanner against the firewall then put the nut on inside the car.
Otherwise just retack it on with a Mig
PostPosted: Mon Mar 17, 2008 8:27 pm
how about just getting someone to help..... one person hold the bolt from the inside with a spanner on it, and the other do up the nut - it's not that hard Josh!
PostPosted: Mon Mar 17, 2008 8:39 pm
a dab of sikaflex & whack it back in
PostPosted: Mon Mar 17, 2008 9:14 pm
High heel ninja
Josh. give me a yell & i'll make the llloooonnnnggggg trip down to your place & i'll help you fix it.
Doogie
PostPosted: Mon Mar 17, 2008 9:20 pm
Woo hoo :D
I'll give ya a bell tommorow 8)
Users browsing this forum: Bing [Bot] and 99 guests
