dtorreal wrote:
Hey Guys
Picked myself up a great buy o the weekend. 67 Deluxe. One owner since new with all the paper work. Will submit photos once i pick it up.
Had a few questions for the NSW guys out there.
1) Can i drive the car with traffic plates to get it back to my place or do i need a 1 day pass from the RTA?
2) What do they look for with blue slips?
3) I know rust is something they look for and to be honest i'm very fortunate that this little guy doesnt have any VISIBLE rust. I do have 1 or 2 Tea Stain rust. Any suggestions on how to cover it up for the time? Ultimate goal is to get the car resprayed again but for the time being just want to pass blue slip.
Thanks in advance ladies and gents.
Hi
I will try to answer your questions.
1. Dont drive it - just dont go there - You havn't told us very much about the car itself but if its been standing for a will you can almost guarrantee the brake and clutch hydraulics are stuffed and its only the first time you do a big stomp that you will find out.
The radiator is probably fill of crap and you don't need to cook the motor on the way home.
Beg, borrow or steal a trailer to bring it home - tie it down with chains, not pissy bits of rope or cheap tie down straps - a car walking off the back of a car trailer is a deadly missile.
Don't hire a trailer though - its actually cheaper to get a tilt tray truck to pick it and delver it than to hire a trailer for this sort of one-off.
Now the law - the law says you can drive an unregistered vehicle from your home to a authorised inspection place or to a recognised place of repair ie - a licenced mechanic or similar. You cannot just put traffic plates on a car and drive it.
Blue slips - blue slips are actually no worse than a pink slip except that a bit more attention is paid to the identifcation of the vehicle. The vehicle needs to clean and tidy and well presented - a shoddy looking vehicle attracts further attention and inspection.
It needs to be roadworthy - it needs to be right and safe to beon the road for both the driver and any passengers and also other road users. They
will check it for the same issues as they do for your pink slip
Most common area of failure for a mini (after stupid owners not checking for blown light bulbs) is oil leaks - Mostly this is just an engine that has 30 years of grease, oil and crap all over it. Beg, borrow, hire or steal a Karcher and give the underbody and the engine a thorough clean. If iit drips oil on the ground after the clean then you will have to fix the oil leak.
Rust - well the car has to be right - it has to be safe. Tea stain rust - polish it out with a cutting compound. The car may go up on a hoist and they may tap on the floor with a sharp probe to see if the floor is paper thin. If they find holes (or make them) then you must fix the rust.
Mike
