whats wrong with my fuel guage https://www.ausmini.com/forums/viewtopic.php?f=2&t=40260 |
Page 1 of 2 |
Author: | carter [ Mon Mar 17, 2008 7:50 pm ] |
Post subject: | whats wrong with my fuel guage |
when i turn on my ignition my fuel guage goes up to about 1/4 but if i tap my speedo where my fuel guage is the fuel guage goes up a bit i tap it again and it keeps going up until it reads full..... it isnt full it only has about 8 litres in it 2 4 litre tins thanks |
Author: | BALLISTIC [ Mon Mar 17, 2008 8:47 pm ] |
what does the temp gauge do?? could be a faulty voltage reg on the back of the speedo housing. 12 volts going in to reg and should have around 8 or nine volts max coming out. |
Author: | Wombat [ Tue Mar 18, 2008 10:48 am ] |
BALLISTIC wrote: what does the temp gauge do??
could be a faulty voltage reg on the back of the speedo housing. 12 volts going in to reg and should have around 8 or nine volts max coming out. Should be 10volts |
Author: | AEG163job [ Tue Mar 18, 2008 2:36 pm ] |
Swap the stabiliser (process of elimination -step 1). |
Author: | Wombat [ Tue Mar 18, 2008 3:34 pm ] |
AEG163job wrote: Swap the stabiliser (process of elimination -step 1).
Or buy one of my solid state electronic ones ![]() |
Author: | AEG163job [ Tue Mar 18, 2008 3:37 pm ] |
What's the $$damage$$ Dave? |
Author: | Wombat [ Tue Mar 18, 2008 3:41 pm ] |
$20 including P&P |
Author: | AEG163job [ Tue Mar 18, 2008 3:47 pm ] |
Want to PM your requirements? address? pete |
Author: | carter [ Tue Mar 18, 2008 4:40 pm ] |
the temp guage is ok so is the oil pressure its just the fuel guage |
Author: | AEG163job [ Tue Mar 18, 2008 4:43 pm ] |
Or maybe per chance the sender unit. process of elimination - step 2- swap sender unit or check variable resistance with multimeter. |
Author: | carter [ Tue Mar 18, 2008 6:52 pm ] |
would it have anything to do with me pulling the guage apart prior to intallment? |
Author: | AEG163job [ Tue Mar 18, 2008 9:59 pm ] |
ah hah, so what have you been fiddling with? |
Author: | carter [ Wed Mar 19, 2008 4:48 pm ] |
just the fuel guage to change the colour of the needle it was faded orange and white looks much beta i then put it bak together and this is what happens? |
Author: | simon k [ Wed Mar 19, 2008 6:00 pm ] |
carter wrote: just the fuel guage to change the colour of the needle it was faded orange and white looks much beta i then put it bak together and this is what happens?
tut tut tut..... do we need to take it apart and check it again? maybe we connected the wires wrong or ..... ? |
Author: | AEG163job [ Thu Mar 20, 2008 8:11 am ] |
simon k wrote: maybe we connected the wires wrong or ..... ?
yes, sounds like some sort of earthing/connection problem. |
