It is currently Sat Jul 26, 2025 6:07 pm
PostPosted: Mon Mar 17, 2008 2:43 pm
Any tips to look for. The sender seems to give varying resistance from 0-ish to about 100ish or something ohms. So I suspect it is in the wiring or something else.
Every now and again the guage starts reading, I thought it was just the float, but its now fixed and guage not working again.
PostPosted: Mon Mar 17, 2008 4:03 pm
The float moves a brass arm that rubs up and down on a copper coil, varying the resistance.
If it reads sometimes I'd say the arm needs more pressure, easy to do once you pull the sender out.
PostPosted: Mon Mar 17, 2008 4:43 pm
How do you do that?
Also, would that still be the case, I mean it varied it's resistance when testing with a multimeter, and so I tried plugging it back in and doing it with someone watching the guage and still no go??
PostPosted: Mon Mar 17, 2008 5:23 pm
I have a majic super rare one....... It is always half-full it never runs out :D :D :D
PostPosted: Mon Mar 17, 2008 6:09 pm
rampage101 wrote:
How do you do that?
How? You take the cover off it and bend the slider a bit so it rubs harder.
I agree though if it reads reliably over its range it is something else.
ground the wire onto the tank body, the gauge should read full scale.
If not, check the +10V supply to the gauge from the voltage stabiliser, or the gauge itself.
PostPosted: Mon Mar 17, 2008 6:58 pm
Ok,
Well, both the temp guage and the fuel guage don't work. I've never had it hot enough though to test the temp guage properly though. So I'm now leaning towards the +10v. Where is this in a clubby? What exactly should i be looking for
PostPosted: Mon Mar 17, 2008 8:57 pm
There's a little tin can in behind the speedo, it takes 12V or whatever the battery/alternator dishes out and reduces it to 10V using `1950s magic' (glorified vibrating bimetal strip). :lol:
If there is 12V going in and 0V coming out, PM wombat for one of his cheap and excellent electronic ones. I run one in each car now. :D
