It is currently Sat Aug 02, 2025 9:51 pm
PostPosted: Mon Mar 17, 2008 7:50 pm
when i turn on my ignition my fuel guage goes up to about 1/4 but if i tap my speedo where my fuel guage is the fuel guage goes up a bit i tap it again and it keeps going up until it reads full..... it isnt full it only has about 8 litres in it 2 4 litre tins thanks
PostPosted: Mon Mar 17, 2008 8:47 pm
what does the temp gauge do??
could be a faulty voltage reg on the back of the speedo housing.
12 volts going in to reg and should have around 8 or nine volts max coming out.
PostPosted: Tue Mar 18, 2008 10:48 am
Should be 10volts
David L
PostPosted: Tue Mar 18, 2008 2:36 pm
Swap the stabiliser (process of elimination -step 1).
PostPosted: Tue Mar 18, 2008 3:34 pm
Or buy one of my solid state electronic ones :wink:
David L
PostPosted: Tue Mar 18, 2008 3:37 pm
What's the $$damage$$ Dave?
PostPosted: Tue Mar 18, 2008 3:41 pm
$20 including P&P
David L
PostPosted: Tue Mar 18, 2008 3:47 pm
Want to PM your requirements? address?
pete
PostPosted: Tue Mar 18, 2008 4:40 pm
the temp guage is ok so is the oil pressure its just the fuel guage
PostPosted: Tue Mar 18, 2008 4:43 pm
Or maybe per chance the sender unit.
process of elimination - step 2- swap sender unit or check variable resistance with multimeter.
PostPosted: Tue Mar 18, 2008 6:52 pm
would it have anything to do with me pulling the guage apart prior to intallment?
PostPosted: Tue Mar 18, 2008 9:59 pm
ah hah, so what have you been fiddling with?
PostPosted: Wed Mar 19, 2008 4:48 pm
just the fuel guage to change the colour of the needle it was faded orange and white looks much beta i then put it bak together and this is what happens?
PostPosted: Wed Mar 19, 2008 6:00 pm
tut tut tut..... do we need to take it apart and check it again? maybe we connected the wires wrong or ..... ?
PostPosted: Thu Mar 20, 2008 8:11 am
yes, sounds like some sort of earthing/connection problem.
Users browsing this forum: fuzzy-hair-man and 88 guests
