Pedal Box and Brake/Clutch Cylinders https://www.ausmini.com/forums/viewtopic.php?f=2&t=40316 |
Page 1 of 2 |
Author: | atowill [ Wed Mar 19, 2008 6:43 pm ] |
Post subject: | Pedal Box and Brake/Clutch Cylinders |
Hey guys, I'm stuck again. How do you get these bloody things apart? It feels like they're all undone, but the piece that the pedal moves still extends into the cylinder. I've had a bit of a search around the site, but apologies ahead if I've overlooked the answer to this one. What should I do? |
Author: | doogie [ Wed Mar 19, 2008 6:50 pm ] |
Have you pull out the clevis pins from the pedal box? Doogie |
Author: | atowill [ Wed Mar 19, 2008 7:11 pm ] |
Adam stares at Doogie with a blank look for a while... So where would I find these, if I haven't moved them yet? Sorry to sound like a moron, but I've never played with this part of the car before today. |
Author: | matt van'74 [ Wed Mar 19, 2008 7:16 pm ] |
Author: | rampage101 [ Wed Mar 19, 2008 7:18 pm ] |
At the end of each pedal there is a hole. At the bottom of the pushrod's to the master cylinders there is a fork type thing that fit either side of the pedal (which also has holes). Through these holes is a clevis pin (Sort of like a short threadless bolt with a hole through it) that joins the two parts in order for the pedal to push the pushrod. |
Author: | matt van'74 [ Wed Mar 19, 2008 7:20 pm ] |
Hop in the driver's foot well. And at the top of the brake and clutch pedal there is a little clevis pin (see pic above) that connects the pedals to the master cylinders. They are often held in with split pins but if you are lucky someone might have fitted r clips. They can also be quite rusty especially if the master cylinders have leaked on to them at some stage in their life. Be patient, most mini owners regard this as one of the most annoying jobs to do. A long pair of long nosed pliers and side cutters make the job easier. Grab a beer and have ago ![]() <edit> Where abouts are you? Fill in your location so if you get really stuck someone might offer their time to help you out. </edit> Matt |
Author: | atowill [ Wed Mar 19, 2008 7:26 pm ] |
Ah, that does make it look a lot easier. Thanks for all your help, guys. I'm gonna wander back up there shortly and have another crack at it. I'll let you know how it all goes. Matt... I'm in Athelstone, South Australia. I'll go fix up my profile details now. ![]() |
Author: | matt van'74 [ Wed Mar 19, 2008 7:28 pm ] |
Let me know if you need a hand. Seeing as we live in the same suburb ![]() Matt |
Author: | atowill [ Wed Mar 19, 2008 7:32 pm ] |
Ahh cool! And there's me thinking that nobody's gonna know where I'm talking about! I'll give it another shot, but I will keep your kind offer in mind. Thank you! |
Author: | matt van'74 [ Wed Mar 19, 2008 7:55 pm ] |
No worries, I can help tomorrow night if you need it but I am away from friday to monday. I will bring my special pliers home from work just in case Matt |
Author: | WantOne [ Wed Mar 19, 2008 9:23 pm ] |
I'm only a couple of minutes away too. And I'm going to be sick tomorrow. I have removed the pedal box before and found it easy once you had the knack. |
Author: | Boyracer [ Wed Mar 19, 2008 9:27 pm ] |
WantOne wrote: And I'm going to be sick tomorrow.
Love it! There's nothing like planning. ![]() |
Author: | Mick [ Wed Mar 19, 2008 9:52 pm ] |
Bring long nose pliers. |
Author: | WantOne [ Wed Mar 19, 2008 10:02 pm ] |
My secret trick is to thread lockwire through the eye of the cotter pin, tighten, twist and pull. Comes out pretty easy compared to stuffing around with screwdrivers and long nose pliers. |
Author: | Mick [ Wed Mar 19, 2008 10:06 pm ] |
WantOne wrote: My secret trick is to thread lockwire through the eye of the cotter pin, tighten, twist and pull. Comes out pretty easy compared to stuffing around with screwdrivers and long nose pliers.
Hmmm...nice... Any good tricks for putting them back ?? I've got the longest pair of long nose pliers in the western hemisphere. They make the best of a bad situation.. |
