It is currently Wed Aug 06, 2025 2:29 am
 Post subject: dash pot oil
PostPosted: Fri Mar 21, 2008 5:24 pm
Hi guys
I am using tranny fluid can anyone tell me how much or to what level I have to fill it?
Do I take the plunger out and pour it in or do I just undo the top and pour it in ontop?
any help will be appreciated
Michael
blokeinamoke wrote:
PostPosted: Fri Mar 21, 2008 5:29 pm
It's meant to simply fill the tube. If you overfill it, the excess will
a) blow out the top as you drive. Or
b) drain down on top of the piston and then into the manifold.
It doesn't really matter, get it within 1/2 an inch from the top of the inner piston tube and it will find it's own happiness. If you overfill it, it will still find it's own level one way or another.
PostPosted: Fri Mar 21, 2008 5:30 pm
Give Ash some flowers Nick .
In addition to what Mick said, leave the little "tube" in there as you fill it, it takes up space and oil will dribble out if you fill it to the correct level and then put it back in.
PostPosted: Fri Mar 21, 2008 6:00 pm
how did you juice him/her? :lol:
sorry, back to the topic...
78 Leyland Mini - Prince
