Gearbox/Engine match https://www.ausmini.com/forums/viewtopic.php?f=2&t=40344 |
Author: | henry the mini [ Thu Mar 20, 2008 7:13 pm ] |
Post subject: | Gearbox/Engine match |
Just a quick question. Can you put a 1100s 1275 onto a 998 gearbox??? |
Author: | drmini in aust [ Thu Mar 20, 2008 7:15 pm ] |
Sure can, straight on if it's a rodchange one, ie 998 Clubby or Rover.. If it's a Mini Deluxe, you can too but may have to grind the old 3 synchro box a bit. You will need to fit a 1275 primary gear... the 998 one won't fit. |
Author: | henry the mini [ Thu Mar 20, 2008 7:18 pm ] |
drmini in aust wrote: Sure can, straight on if it's a rodchange one, ie 998 Clubby or Rover..
If it's a Mini Deluxe, you can too but may have to grind the old 3 synchro box a bit. You will need to fit a 1275 primary gear... the 998 one won't fit. It's a remote type, is it the same deal |
Author: | drmini in aust [ Thu Mar 20, 2008 7:30 pm ] |
henry the mini wrote: drmini in aust wrote: Sure can, straight on if it's a rodchange one, ie 998 Clubby or Rover.. If it's a Mini Deluxe, you can too but may have to grind the old 3 synchro box a bit. You will need to fit a 1275 primary gear... the 998 one won't fit. It's a remote type, is it the same deal is it 3 synchro or 4 4 synchro no prob. |
Author: | henry the mini [ Thu Mar 20, 2008 7:39 pm ] |
4 crunching gear ![]() |
Author: | drmini in aust [ Thu Mar 20, 2008 9:33 pm ] |
I'll make this easier... Give me the casting number on front of box... ![]() |
