It is currently Thu Aug 14, 2025 2:03 am
 Post subject: Disc brake question?
PostPosted: Thu Mar 20, 2008 7:34 pm
Hi All,
Can anyone identify my disc brakes please?, they have the following part number....21A266. What are they off etc...
Chris.
63 Morris Cooper.
UK Mini van.
PostPosted: Thu Mar 20, 2008 7:40 pm
Easiest, quickest, best way is to measure the diameter of the disc. It will be either 7 inches for a 997,998 Cooper disc. 7.5 for the Cooper S type or 8.4 for late Clubman/Rover discs.
You can tell visually by looking at the disc as well. Cooper 7" will have a small nut on the end of the driveshaft holding the whole lot on, 7.5" will have a larger (32mm) nut and 4 countersunk phillips head screws on the outer face (where the wheel butts up to the disc brake assembly) and 8.4" discs will have four recessed bolts in this same face instead.
PostPosted: Thu Mar 20, 2008 7:45 pm
Don't recognise that particular part number but a 21A1265 is a Cooper "S" 7.5" brake disc.
1964 998 Cooper , 1968 Morris 1100
 Post subject: Brake disc question
PostPosted: Sat Mar 22, 2008 9:08 am
Thanks guys, I'll take a close look.
Chris.
63 Morris Cooper.
UK Mini van.
Users browsing this forum: No registered users and 227 guests
