Plastic Brake/Clutch Fluid Reservoirs https://www.ausmini.com/forums/viewtopic.php?f=2&t=4042 |
Author: | FatMaserati [ Fri Jan 14, 2005 9:14 pm ] |
Post subject: | Plastic Brake/Clutch Fluid Reservoirs |
I think both of my plastic brake and clutch fluid reservoirs are cracked, or at least leaking in some way. I know they don't make them new anymore, so what's the best way to fix them? Is it just worth buying new master cylinders with tin tanks? This is for a mini I intend to keep for ages, so I want it done right, if you know what I mean. Nothing too dodge. |
Author: | 9YaTaH [ Fri Jan 14, 2005 9:19 pm ] |
Post subject: | Re: Plastic Brake/Clutch Fluid Reservoirs |
FatMaserati wrote: I think both of my plastic brake and clutch fluid reservoirs are cracked, or at least leaking in some way. I know they don't make them new anymore, so what's the best way to fix them? Is it just worth buying new master cylinders with tin tanks? This is for a mini I intend to keep for ages, so I want it done right, if you know what I mean. Nothing too dodge.
Nothing dodgey about Tin Tanks just a little less volume....get hold of some replacements and get them sleeved and an overhaul kit put through them ....hey!! get them chromed up ya have more bling! ![]() |
Author: | FatMaserati [ Fri Jan 14, 2005 9:22 pm ] |
I suppose if I get the larger tin tank models, it should be hunky dory. Has anybody thought of fashioning some kind of tin tank that screws in the way the plastic tanks do? |
Author: | Mini Mad [ Fri Jan 14, 2005 9:50 pm ] |
Don't the Tin one's line up with the same holes? I also thought you could buy plastic ones still new? I just got a new plastic clutch master cylinder from Karcraft.. ![]() |
Author: | drmini in aust [ Fri Jan 14, 2005 10:20 pm ] |
Josh, he's talking about the old Lockheed/PBR ones with the plastic tank & big screwtop lid. NLA. The latest ones do have a plastic tank, it goes around the cylinder, sort-of like the old tin ones. At least they are new, so will last for years! ![]() |
Author: | Mini Mad [ Fri Jan 14, 2005 10:29 pm ] |
fair enough ![]() ![]() |
Author: | FatMaserati [ Fri Jan 14, 2005 10:58 pm ] |
Thanks Doc, I did mean the old Lockheed/PBR ones. I'll probably just end up getting tin tanks. |
Author: | min13k [ Fri Jan 14, 2005 11:17 pm ] |
might have a cpl here bud i'll have a look when i can get near the shed makka |
Author: | FatMaserati [ Mon Jan 17, 2005 12:06 am ] |
Thanks, but I think I've fixed the problem. I found a few tiny (TINY tiny) cracks which I patched up with Aryldite. I then just cleaned the connection between the plastic tanks and the master cylinders and made sure they were screwed in a little tighter. I also fiddled with the rubber inserts a little to make them fit tighter. Hasn't leaked since. |
