Alternate Fuel Gauges ?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=40463
Author:  MINImal effort [ Tue Mar 25, 2008 7:27 pm ]
Post subject:  Alternate Fuel Gauges ?
My Clubman had a custom dash put in it before I bought it (many many moons ago now) and is using a VDO fuel Gauge.
When I swapped the parts over to another mini the fuel guage starting working backwards.... and inaccurately. :?
After some research on the web finally understand why....
as VDO are 180 Ohms Full and 10 Ohms Empty.
Whereas Smiths (early) are 20 Ohms Full and 260 Ohms Empty ( and testing on a spare mini fuel tank confirms this.. )( hence backwards reading VDO! :shock: )
Looking at the old car the PO had fitted a VDO sender in the tank - but it has not survived the years sitting around.... (so the simple solution of swapping tanks is out) :cry:
So finally...
Does anyone know any other suitable Smiths (or other) 52mm gauges that can be hooked up with a Mini fuel sender that are reasonably accurate?
I was about to chase up a Triumph Spitfire one on eBay UK - but a quick google seems these are 200 ohms empty.... just when I thought I had a solution ! :roll:
A bit of an odd question I know... but some of you may have hit this sort of thing before...
Thanks
Author:  Harley [ Tue Mar 25, 2008 7:37 pm ]
Whilst I'm googling "resistance inverter", I'll ask the simple question, is it possible to fit the fuel level sender in upside-down?
Or, can you open the gauge, and change the E & F positions with something (as in better than crayon).
:D
Author:  MINImal effort [ Tue Mar 25, 2008 7:42 pm ]
Thanks for the idea .. but...
The sender only goes in one way - there are tabs to ensure this - so float is able to move correctly.
I have found some references to building electronic gizmos with variable resistors to "invert" and calibrate ... but that's getting too complicated!
(It'd be easier to buy a new VDO sender... but trying to do this "cheaply" and avoid similar issues in the future... )
And with the VDO reading "FULL = empty" at 180 - there is still plenty of Fuel in the tank... but for long ??
Author:  EST-071 [ Tue Mar 25, 2008 8:03 pm ]
What does the sender read in a Rover Mini as they have a different brand gauge.
Cheers Pete
Author:  Hanra [ Tue Mar 25, 2008 8:45 pm ]
Check Autometer. They also making a gauge that can learn. You set the sender to empty and program the gauge, then set the sender to full and program the gauge again. Its probably not cheap, but will work in the end.
Author:  Jules [ Thu Apr 03, 2008 12:51 am ]
There are several different versions of the VDO gauge, to cater for different sender units. Some work in the 'forwards' sense and some the other way round.
If you need help to find the right one I've got the catalogue here so just tell me the empty and full resistance of your sender and I'll have a look.
Author:  justminis [ Thu Apr 03, 2008 7:17 am ]
I use a 2" etc Smiths fuel gauge in my Black S that matches the S oil pressure and temp gauges. Works a treat. Sourced it from Lionel Otto Instruments in Brisbane. Set the resistence at the time.
Contact John on 07 3277 3888. These guys are great.
Author:  MINImal effort [ Wed May 28, 2008 6:51 pm ]
Footnote to this thread .... (for anyone looking for this sort of info in the future)
Bought a Triumph (Smiths) Fuel gauge (and voltmeter) off eBay for $10..... :D
Calibrated it with a sender out of a spare tank as per http://www.mgb-stuff.org.uk/fuel.htm
And works perfectly....
Brother-In-Law borrowed the Mini and returned it with
B*gger all petrol in it
and I then fitted the gauge - read zero....
Just filled up .. 23 litres ... and sitting at FULL...
Much better than the wacko readings from the VDO....
Author:  meehal [ Thu May 29, 2008 12:09 pm ]
I'm having a similar issue going from an 850 speedo to a black face speedo from an unknown roundy. Has anyone else done the same and found the same issue, and can it be calibrated in a similar way?
Author:  simon k [ Thu May 29, 2008 12:42 pm ]
the fuel gauges should work the same way..... maybe the ont in the black face speedo is just dodgy. You can swap the fuel gauges over
my mate has a VDO gauge that he's installed in a roundie, and modified the VDO sender unit to fit in a standard tank - let me know if anyone wants his contact details to find out what he did
Author:  meehal [ Thu May 29, 2008 2:17 pm ]
I have considered trying to swap the fuel gauge out of the speedo, the gauge in the 850 speedo works fine. Except the needle wobbles a bit.
I'll trying swapping them over.
Thanks for that.
Author:  MINImal effort [ Thu May 29, 2008 7:07 pm ]
What age is the 850 ?
In my research I found info that pre 1964 Fuel gauges are different to later ones in the UK.
I guess that the same would apply to Australian cars as cars/ parts were sourced from the UK initially.
If this is the case then you'd have to re-use your existing gauge - or update the tank sender to a later one.
"dklawson" on the miniforum site has some good info in a few threads....
see 2nd post in this thread -
http://www.theminiforum.co.uk/forums/index.php?s=9e47e74e0cc2b1b2b7c6790029576af2&showtopic=46027&pid=515864&st=0&#entry515864
