It is currently Sun Aug 03, 2025 10:02 pm
 Post subject: basic air fuel ratio
PostPosted: Wed Mar 26, 2008 9:02 am
hey guys,
want to set the ratio so i can get the thing to atleast run a bit.
its a 1.5 su of a rover.
how many turns of the nut etc would you guys do?
cheers jamie
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Wed Mar 26, 2008 9:24 am
It's been a while... but I think you need to take the dashpot off, screw the jet until it is level with the bridge (you should see what thay means) and then 'unscrew (move down)' the jet 8 flats (or 1 and 1/3 turns)...
But that's only a starting point...
PostPosted: Wed Mar 26, 2008 9:37 am
Turn nut down to richen and up to lean out. There is no settings all engines are diffrent depending on the state of tune of engine. To get a correct air/fuel ratio you need a good air/fuel ratio meter
PostPosted: Wed Mar 26, 2008 10:10 am
This space for rent
I always took Vizard's advice and went 14 flats (2-1/3 turns) from the bridge.. I usually find that setting is only 3 flats or so either way from stoich according to the Colourtune.
That's on HS2's though, I assume that's still correct for the HS4.
Users browsing this forum: Barkfast and 81 guests
