basic air fuel ratio https://www.ausmini.com/forums/viewtopic.php?f=2&t=40477 |
Author: | mad-mk1 [ Wed Mar 26, 2008 9:02 am ] |
Post subject: | basic air fuel ratio |
hey guys, want to set the ratio so i can get the thing to atleast run a bit. its a 1.5 su of a rover. how many turns of the nut etc would you guys do? cheers jamie |
Author: | miniobsessed [ Wed Mar 26, 2008 9:24 am ] |
It's been a while... but I think you need to take the dashpot off, screw the jet until it is level with the bridge (you should see what thay means) and then 'unscrew (move down)' the jet 8 flats (or 1 and 1/3 turns)... But that's only a starting point... |
Author: | mason [ Wed Mar 26, 2008 9:37 am ] |
Turn nut down to richen and up to lean out. There is no settings all engines are diffrent depending on the state of tune of engine. To get a correct air/fuel ratio you need a good air/fuel ratio meter |
Author: | sgc [ Wed Mar 26, 2008 10:10 am ] |
miniobsessed wrote: It's been a while... but I think you need to take the dashpot off, screw the jet until it is level with the bridge (you should see what thay means) and then 'unscrew (move down)' the jet 8 flats (or 1 and 1/3 turns)...
But that's only a starting point... I always took Vizard's advice and went 14 flats (2-1/3 turns) from the bridge.. I usually find that setting is only 3 flats or so either way from stoich according to the Colourtune. That's on HS2's though, I assume that's still correct for the HS4. |
