It is currently Wed Jul 30, 2025 2:09 pm
 Post subject: molasses warning
PostPosted: Wed Mar 26, 2008 7:00 pm
I just pulled some parts out of my molasses bath and was a bit shocked at the results :oops: , (in all fairness the mix was 1:5 and I did leave the parts in and unchecked for a bit over 2 months) in my defence I'm a bit lazy :roll: . the parts were 2 sets of front suspension arms, 1 set of rear trailing arms, 1 set of suspension arm bolts with the curve in them, a pair of rear hubs and some front subby spacers.
This is what came out :shock: (I pulled them out and pressure washed them yesterday arvo and then left them outside over night which will explain the surface rust).
Notice the pitting
and the worst...wheres my thread gone :?:
I'm sure they weren't that rusty when I put them in but I may not have noticed. The pair of trailing arms are the only parts that came out like that, all other threads are fine :D .
Now for the experts, is it worth re-threading them?
Is it possible to replace the pins? (are the trailing arms a one piece item or is the threaded part pressed in?)
and lastly what would I expect to pay for a new/2nd hand set of rear trailing arms? and is it worth going for a new set or not?
TEND YOUR MOLASSES BATH
PostPosted: Wed Mar 26, 2008 7:26 pm
I'd suggest you take that lot to the tip. Not worth re-threading anything or replacing the pins. Pretty well rooted IMO.
Better to find some good S/H items.
You live & learn. I left some degreaser (the water soluble stuff) in my brand new Supertool bath for a couple of months and it virtually ate the bottom out. Some of these chemicals are pretty corrosive if left unattended.
PostPosted: Wed Mar 26, 2008 7:40 pm
The sugar changed to acid I think....much like on your teeth if you drink a stiff red cordial before nigh nigh...
PostPosted: Wed Mar 26, 2008 10:56 pm
wow!, i should put that picture on my horses jar like a goverment health warning label.
Davids Automotive Detailing: 0467 629 947
Professional Buff & Polish- Scratch, swirl removel
https://www.facebook.com/pages/Davids-A ... n=timeline
PostPosted: Thu Mar 27, 2008 5:59 am
That's it, no more Bundy for me!!
I'm going back to beer!
Image Image
PostPosted: Thu Mar 27, 2008 8:50 am
The arms should be OK buy new pins
David L
PostPosted: Thu Mar 27, 2008 10:27 am
wow... so the railway sleeper nails I put in a container with molasses about 14 months ago and forgot about won't be any good now
bin the lot - replacing all those bits will be $$$
