Good feeling job well done then oh bugger! https://www.ausmini.com/forums/viewtopic.php?f=2&t=4050 |
Author: | Wombat [ Sat Jan 15, 2005 5:38 pm ] |
Post subject: | Good feeling job well done then oh bugger! |
Just swapped the oil filter head over to a spin on, ![]() ![]() The gap at the top of the filter head dampened the good feeling - is all I need a different gasket or is plate or something missing? |
Author: | drmini in aust [ Sat Jan 15, 2005 7:18 pm ] |
Yes, it's a totally different shaped gasket, weird shape. |
Author: | dr trim [ Sat Jan 15, 2005 11:24 pm ] |
i want to do this aswell. i have the piece that goes from the upper part of the block, and has a pipe running down to the main housing which the spin on must mount to. what else do i need? |
Author: | drmini in aust [ Sun Jan 16, 2005 5:57 am ] |
The gasket, and 2 short 3/8" bolts. The existing long studs you pull out. |
Author: | aaron [ Sun Jan 16, 2005 6:27 am ] |
Have you removed the spacer from the block. I know mine was painted and looked like it was a part of the block. Once removed i just used some gasket maker and it works a treat. no leaks at all. Cheers aaron |
Author: | gafmo [ Sun Jan 16, 2005 8:27 am ] |
Do the Bling Bling before you put it on ![]() ![]() |
Author: | dr trim [ Sun Jan 16, 2005 9:27 am ] |
i'll give it a go next weekend, thanks diggers ![]() |
Author: | 1310/71 [ Sun Jan 16, 2005 10:14 am ] |
gafmo wrote: Do the Bling Bling before you put it on
![]() ![]() Hey that looks great, why didn't I think of that. I almost hate to ask - how long did that take you? KB |
Author: | gafmo [ Sun Jan 16, 2005 10:43 am ] |
And thanks to you I have been able to Bling Bling it. It took me another 3-4 Hours worth of polishing. I'm now working on another peice of the engine bay and the the Dellorto. I wish I had a bremill though ![]() |
Author: | 1310/71 [ Sun Jan 16, 2005 12:28 pm ] |
gafmo wrote: And thanks to you I have been able to Bling Bling it.
It took me another 3-4 Hours worth of polishing. I'm now working on another peice of the engine bay and the the Dellorto. I wish I had a bremill though ![]() Do you mean a Dremel? KB's treasure trove of a garage has one of those in the cupboard! I still think it would take a while with the dremel though (fairly small contact point). I'm back at work next week, but ring or PM if you want to try it. KB |
Author: | gafmo [ Sun Jan 16, 2005 1:16 pm ] |
Yer thats it.....I'll be fine and give the old fingers a work out ![]() |
Author: | 68matic [ Sun Jan 16, 2005 1:44 pm ] |
![]() **** me gafmo you bling bling everything i can just imagine you sitting there like a kid for hours on end rubbing and rubbing btw how did the subframes go |
