pulling a mini apart https://www.ausmini.com/forums/viewtopic.php?f=2&t=40544 |
Page 1 of 2 |
Author: | Kennomini [ Fri Mar 28, 2008 5:32 pm ] |
Post subject: | pulling a mini apart |
I'm starting to strip Sonic and I can't figure out how to remove the hood lining. The car is a 1962 Morris 850. Mine has a screw at the top of the B pillar on either side(I have removed these), dose the rear half come forwards or dose the front half go backwards ![]() ![]() Also what is the best way to strip the doors? (early model wind ups) dose the 1/4 glass come out first and then the main glass or what ![]() |
Author: | Brick*Racer [ Fri Mar 28, 2008 5:44 pm ] |
if done this on an LS so im not sure if its the same but yeah i had to take the quater window out first before the main window....but that was a long time ago so maybe someone has a better way of doing it ![]() |
Author: | Kennomini [ Fri Mar 28, 2008 5:47 pm ] |
Also dose the 1/4 window come in or out as your pulling it out? That's a bit hard to understand but yous will get it ![]() |
Author: | sports850 [ Fri Mar 28, 2008 5:48 pm ] |
An 850 has a different hood lining to most other mini's (same with 997/8 coopers I think) , they are a two part light steel frame that comes out intact as two parts . Basically remove the 2 screws and then gently pull the rear half (I think it's rear , the one on the bottom where they overlap anyway) down and forward at the front and it'll "pop" out . It's a snug fit and holds itself in by tension mostly . Once that halfs out pull the other out the same . Once it's out you'll see the hoodlining is stapled to the frame , remove the staples and peel the edges off where they are glued and get the neew hoodlining made up using the old one as a pattern . |
Author: | Kennomini [ Sat Mar 29, 2008 5:53 pm ] |
cool I'll give that a go Sports 850. Couple of other issues, the + battery lead. Were is it ment to run because mine goes from the battery up the C pillar, along/inside the drivers side roof Chanel and down the A pillar, then through the dash/firewall and in to the engine bay. Is this correct? and comments please... And just checking the standard fuel tank holds how many liters? I really do need an exact figure please. |
Author: | drmini in aust [ Sat Mar 29, 2008 5:56 pm ] |
The battery cable on an 850 runs along inside the centre tunnel on the RH side. or it should.... ![]() |
Author: | 9YaTaH [ Sun Mar 30, 2008 7:02 pm ] |
Post subject: | 5.5 gallons |
Kennomini wrote: And just checking the standard fuel tank holds how many liters? I really do need an exact figure please.
25 litres |
Author: | Kennomini [ Sun Mar 30, 2008 7:21 pm ] |
Post subject: | Re: 5.5 gallons |
9YaTaH wrote: Kennomini wrote: And just checking the standard fuel tank holds how many liters? I really do need an exact figure please. 25 litres awesome, this will become relevant to you' all when I finish ![]() ![]() |
Author: | Kennomini [ Tue Apr 01, 2008 5:54 pm ] |
Still having difficulties with the 850 hood lining. I've pulled the front section backwards and uncliped it from the rear 1/2 but how exactly do I get them out from their? Do I just pull the middles straight down against the curve of the hoops or what, I just don't want to wreck them ![]() And a progress report, after 4 1/2 hours I've striped the boot, interior (except the dash), removed all the glass from the body. All that's left is the dash, doors, subframes, engine and wiring loom ![]() |
Author: | brett [ Tue Apr 01, 2008 9:50 pm ] |
9YaTaH wrote: Kennomini wrote: And just checking the standard fuel tank holds how many liters? I really do need an exact figure please. 25 litres But have you allowed for the fuel in the line and the carbys fuel float? Sounds a bid dodgy to me Ken. sure your not trying to blow something up are you ![]() ![]() |
Author: | Kennomini [ Tue Apr 01, 2008 10:11 pm ] |
no...well not on the mini anyway ![]() ![]() |
Author: | sports850 [ Wed Apr 02, 2008 6:23 am ] |
Kennomini wrote: Still having difficulties with the 850 hood lining. I've pulled the front section backwards and uncliped it from the rear 1/2 but how exactly do I get them out from their?
Do I just pull the middles straight down against the curve of the hoops or what, I just don't want to wreck them ![]() Pretty much , they are likely to have "grown" into place a little over the last 40 years or so and stuck to the paintwork . Just ease them out gently and you'll be fine . |
Author: | drmini in aust [ Wed Apr 02, 2008 7:07 am ] |
If you pull the 2 corners slightly towards the middle and wiggle it, each 1/2 should slide out. |
Author: | Ben_Aus_Mini [ Wed Apr 02, 2008 10:22 am ] |
Just a question that relates to the hood-lining Do you need to take the windscreen, the back window, and any windows out first before you install a new hood lining? Thanks |
Author: | sports850 [ Wed Apr 02, 2008 11:04 am ] |
Ben_Aus_Mini wrote: Just a question that relates to the hood-lining
Do you need to take the windscreen, the back window, and any windows out first before you install a new hood lining? Thanks It depends on what type of hoodlining you have , 850's up to late 1963/early 1964 (but vague as all BMC stuff was) had a 2 piece framed hoodlinging that sat up in the roof area whereas later ones had a one piece hoodlining that extended to go under the top of the front and rear windscreens anbd under the rubbers for the doors and side windows . Is there painted metal visible between the top of your windscreen and the hoodlining or does the materialgo all the way down under the windscreen rubber . Your's could have either given it's age (1964) and the custom work on it . |
