Help Please https://www.ausmini.com/forums/viewtopic.php?f=2&t=40555 |
Author: | Wombat [ Sat Mar 29, 2008 10:03 am ] |
Post subject: | Help Please |
I've got a new layshaft washer and the tab at the top has too much radius in the bend and it won't sit flush. I thought at first the bent tab was too long on the horizontal plane and ground a bit off so it would drop down into the slot but that didn't solve the problem and now I can see the radius problem. In the pic the new one is on the left and the old one on the right. You can see how the old one has a sharper right angle. Any ideas how to "improve the angle" without stuffing up the washer? ![]() |
Author: | norton [ Sat Mar 29, 2008 10:12 am ] |
Maybe you could take a little bit out of the gearbox, give the box the same radius. |
Author: | drmini in aust [ Sat Mar 29, 2008 11:04 am ] |
File a bigger flat on the box to clear, it should not touch the box there anyway. ![]() |
Author: | Wombat [ Sat Mar 29, 2008 1:31 pm ] |
Thanks guys - filed a round edge on the box lip and it sat in nicely - put the laygear in with the new shaft,bearings and washers and ended up with 0.004" clearance ![]() |
