It is currently Thu Aug 14, 2025 5:05 am
 Post subject: speco tacho (diode)
PostPosted: Fri Apr 18, 2008 11:58 pm
I'm Ernie , Where's Bert ?
hey guys
firstly before i get flamed for not using the search tool...i have :lol:
so anyway:
i am going to be wiring up the tacho tommorow. i reckon ill have no problems wiring up most of it (ive allready got a tacho installed, so i can trace wires) but the one thing that has me muddled, is the instructions tell you
"for Points ignition vehicles
when fitting a speco meter tachometer to points ignition it MAY be necessary to fit the enclosed 1 amp rectifier diode"
it then goes on to say that for 'mini minors':
"many of these vehicles will not operate an aftermarket tacho when fitted. it may be necessary to fit a 3amp universal diode in line in the coil wire"
SOOOOO>
my questions are:
1. if i wire up the tacho without the diode (it may not nned it, correct??? :? ) will this cause any damage to the gauge?
2. should i be wiring up the 3amp universal diode from the very start?
3. (if applicable) HOW do i wire in the diode.....from my research and basic electronics i know it goes on the wire (duh), but do i cut the wire, solder in this diode inbetween the two bits of wire.....OR....???????
Cheers guys
(oh and mods if you wanna move this thread to somewhere else thats allgood) :lol:
00' Forester GT
PostPosted: Sat Apr 19, 2008 8:58 am
If you need a diode and don't put it in there is a high probability you could bugger the taco. Put it in anyway - won't harm if not needed
Put it at either end of the connecting wire - no need to cut unless you can't get at the ends - and yes solder the connections and preferably shrink wrap the joins
David L
PostPosted: Sat Apr 19, 2008 9:07 am
Don't solder until you have tested it, if the diode is reversed the motor won't run. 8)
PostPosted: Sat Apr 19, 2008 12:12 pm
sorry i just want to check...
um...so ive got my green wire thats heading to the coil.....do i cut that wire and solder in that diode (after testing which direction it faces) in between those 2 bits of wire??
thanks
00' Forester GT
PostPosted: Sat Apr 19, 2008 12:34 pm
Yes.
PostPosted: Sat Apr 19, 2008 1:22 pm
Show us your guages
PostPosted: Sun Apr 20, 2008 12:39 am
thanks heaps for the help guys
installed it tonight....had a few hiccups due to the diode, firstly not facing the correct way, then not getting connection to the wire (what do you expect when a lazy-ass like me puts it in elec tape and expects it to work :lol: ) , but now its working nicely. 8)
thanks again :D
00' Forester GT
Users browsing this forum: No registered users and 276 guests
