arpy69 wrote:
I finally fished out the dizzy drive shaft from the gearbox with the help of a $2.50 magnety thing from Supercrap.
I refitted the drive one tooth around (as I was having trouble getting it started on the original setting - see earlier post). So now, when I have #1 at TDC the rotor points to around 10 oclock. I have set the dizzy body so that the rotor is pointing to one of the leads and I have connected that to No1 and then 3,4,2.
Trouble is no matter how I move it back or forwards it won't start! I get some popping but no attempt to start. I have even tried turning the drive dog 180 but no difference
I have to confess that I don't understand the docs comment in the How to thread that "the key part on the driveshaft is below centre" Does this refer to the two lugs on the drive dog or the centre bit with the slot in it?Could the coil be stuffed! It is the one I got with the dizzy from the wreckers. Is there any way I can test it?
I really need some help here folks - it is driving me crazy
Rick
When you look at the slot on the dizzy driveshaft (wot U dropped
) at TDC firing on #1 cylinder, the slot is at an angle to horizontal but below centre. The rotor should be pointing around 1 o'clock when fitted in. If it's pointing to 7 o'clock the drive dog is on arse about.
Firing point is approximately when the peaks on the 4 cornered thingy pass the metal strip on the baseplate. Set like that and then advanced (turn dizzy clockwise) a few degrees, it should start. You will need a strobe timing light to set timing properly....
Remember, firing order is 1-3-4-2 turning anti-clockwise.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
