Freighting the block https://www.ausmini.com/forums/viewtopic.php?f=2&t=40780 |
Author: | Wombat [ Sat Apr 05, 2008 12:29 pm ] |
Post subject: | Freighting the block |
How would you package a block and loose bits( crank, rods, flywheel, cam etc) to send interstate for a bore and assemble by the man? |
Author: | drmini in aust [ Sat Apr 05, 2008 2:07 pm ] |
I'd put all loose bits in a box, then strap or shrink wrap it all onto a pallet... |
Author: | Matt68 [ Mon Apr 07, 2008 9:01 am ] |
I sent an assembled short motor in one (sturdy) carton to GR from Warwick in QLD. Lined the insides with Ply then filled all gaps with foam. I sent the flywheel, balancer etc in a seperate box. Total weight was around 65kg. Sent it by AAE (offpeak) as that is my work's courier co. Should have seen the look on the delivery guy's face when he went to lift it. I told him it was very heavy, he tried to lift it anyways! ![]() ![]() ![]() ![]() |
Author: | Morris 1100 [ Mon Apr 07, 2008 8:02 pm ] |
Plastic crate with lid, the type with the clip on lid. When I was doing courier work we used to deliver a lot of parts shipped this way. |
Author: | Wombat [ Mon Apr 07, 2008 8:20 pm ] |
Morris 1100 wrote: Plastic crate with lid, the type with the clip on lid.
When I was doing courier work we used to deliver a lot of parts shipped this way. Hmmm -- beats trying to build one out of plywood and pine slats. ![]() Had planned to use garbage bags and squirt some of the pressure pack foam into them and let them form 'shaped' packing material. |
Author: | sports850 [ Mon Apr 07, 2008 8:41 pm ] |
That sounds a great idea wombat , keep it all nice and snug in the box/crate without adding too mudh extra weight or mess . |
